It finally started !!!!
Old Aug 6, 2002 | 07:19 PM
danzig74c's Avatar
danzig74c
Default It finally started !!!!
Whit helps from 2 friends from the independent corvetteclub Holland
twinny and xdude jup the guy's from the twin turbo :D
It finally started my vett is going to pieces :D
I finally had the space to start the project so whish me luck I need it :lol:
:eek: :eek: :eek: :D
don't you love it :p:
Old Aug 6, 2002 | 07:24 PM
QuickVet's Avatar
QuickVet
Default Re: It finally started !!!! (danzig74c)
Congrats. that doesnt look so bad. The only part that scares me is the electical wiring. you will be done in no time :cheers:
Old Aug 6, 2002 | 07:30 PM
danzig74c's Avatar
danzig74c
Default Re: It finally started !!!! (QuickVet)
yup the electical wiring is a mess but it will be a body off resto
i will take my time and also enjoy working on it :D
Old Aug 6, 2002 | 07:33 PM
PatsLs1vette's Avatar
PatsLs1vette
well good luck at least you got some help there. :cheers: keep us posted how things are coming along
Old Aug 6, 2002 | 07:53 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: It finally started !!!! (pats406nitrovette)
Hey D :)
:cheers:
The Electrics are a nightmare :) There's an almost untraceable problem w/ the ignition and it's becasue of that wiring.
Marck
[Modified by Twinnie, 5:54 PM 8/6/2002]
Old Aug 6, 2002 | 08:09 PM
danzig74c's Avatar
danzig74c
Default Re: It finally started !!!! (Twinnie)
my hero !!!!! :cheers:
also a proud member i see ;) :cheers:
Old Aug 6, 2002 | 09:19 PM
Red70's Avatar
Red70
Did the front clip come off unharmed? From the pics, it looks like a really clean removal! I have asked others how this is done, but I always hear that they are usually damaged in the process. I'm doing a frame off on my '70, and I'm almost positive I have a rusty birdcage. Any thoughts would be helpful.
Good luck on your project!
Old Aug 6, 2002 | 09:26 PM
Wilson6t7's Avatar
Wilson6t7
Oi :eek: :eek: :eek: Thats a project and a half...
Old Aug 6, 2002 | 09:50 PM
A C's Avatar
A C
Cruise-In II Veteran
Default Re: It finally started !!!! (Micky T)
Check out http://www.lectriclimited.com/ for a wiring harness. They are not cheap, but I can vouch for their quality. They are an exact duplicate of the original. Good luck. :cheers:
AC
Old Aug 7, 2002 | 06:38 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: It finally started !!!! (Red70)
Came off in one piece and intact
If you're meticulous and start from the bottom (where the door is) then carefully use a chisel to break loose, then carefully pull to see if it comes loose, if not chisel more and maybe start at the top. You'll have to saw through thr small fiberglass strip running over the cowl.
Remember to remove the frame extensions too, on danzigs car some doofus welded them to the frame wich made removal of the front clip a pain.
If you need more info, ask for it, I have a damaged no 1 body mount on my birdcage and have started the repair yesterday, I got this far:
Before (after removal of clip)
After removal of firewall
And after removal of damaged parts
But this steers away from Dennis's post so please start a new topic or email :)
Marck
Old Aug 7, 2002 | 07:27 AM
Nomad78SA's Avatar
Nomad78SA
I am impressed and like what I see, been there myself....I will be starting on the wiring harness installation soon myselk
Neil in Tenn
Old Aug 7, 2002 | 01:10 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Wow, you have a big project ahead of you. I wish you luck and patience. Keep the pictures comming, they are great to see.
Old Aug 7, 2002 | 01:40 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: It finally started !!!! (burners)
Hey Dennis,
You have pics of the front clip right ?
Old Aug 7, 2002 | 03:33 PM
danzig74c's Avatar
danzig74c
yup :)
Old Aug 7, 2002 | 06:18 PM
Twin_Turbo's Avatar
Twin_Turbo
There it is :) in 1 piece :D
Old Aug 8, 2002 | 03:51 PM
danzig74c's Avatar
danzig74c
you ask i give :D
Old Aug 8, 2002 | 04:13 PM
groovyjay's Avatar
groovyjay
G'n'R: All you need is just a little patience... :yesnod:
Old Aug 8, 2002 | 05:01 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: It finally started !!!! (groovyjay)
:) If it's not death & decay Danzig doesn't like it :D
Old Aug 10, 2002 | 06:39 PM
danzig74c's Avatar
danzig74c
true :D
To It finally started !!!!
