There is significant play in the steering column of about one inch.
You can move the steering wheel without movement in the steering column itself
It is a non-tilt, non-tele column
The play is purely rotational, you cannot move the wheel up and down or left to right.
What are the wear points that could contribute to this issue? Currently it is too dangerous to drive on the motorway as I cannot keep the car in one lane without significant effort.
The following components have been installed in an effort to remedy the issue:
Same column that's in my 6t8, the steering column shaft has a splined hub up top that the steer wheel bolts to, held on with a nut. The shaft itself is 2 piece the solid piece on top, that slides into the bottom in case of an accident [collaspeable], then the rag joint is fit to the lower shaft on another spline supported on top and bottom with bearings. Hold the rag joint with one hand and slowly rotate steer wheel, you should be able to feel if there is any play in the shaft itself, probably not. I found the play in mine to be a lower bearing failure. Note; lower brg on 68s might be a 67 brg. Since you upgraded to the Borg setup, how hard was it to get the lower shaft to collapse into the top? If it went real easy then the play might be there. T
I just tried turning the wheel while holding the rag joint and can confirm that you can turn the wheel independently of the steering shaft. The play is in the shaft.
Pop the horn button off and see if it's the wheel loose [6screws], take nut off look at spline for slop. If ok here then it's the shaft. For shaft replacement column removal and dissasembly required. Way to much salt and snow on my roads to drive a corvette. T
I started disassembling the column and realised I need a hub puller so I'll get one in the weekend. The steering wheel was bolted on tight so it must be the splines. The bearings feel pretty bad so I'll probably just pull the column anyway for a rebuild
Hey Whitey, there are some other very interesting posts regarding replacing columns. The tilt is desireable, you loose the collaspeable feature of the OEM column. Read there add very closely for all the additional parts needed and make sure the lower mounting to firewall is correct. The 68 is unique, a one year only column. It's only January, take the time and do the research. Since you're good enough to get the column out you are capable of repairing you're column with a $100 of parts. I was looking to do same as you, but the price of an aftermarket column install was getting close to $1000. T
I think the 67 and 68 columns are the same. They are not too difficult to rebuild. Get the Dr. Rebuild catalog and review the diagrams. They have most all the parts you need. Good luck. Jerry
The 1967 and 1968 Vette columns will not interchange. The jacket and mounting system up into the dash are different. The lower end of the 1967 column has a bracket on the engine side of the dash that clamps on the jacket. The 1968 column has a welded bracket that bolts to the passenger side of the dash.
The overall length of the two steering columns are the same. I am quite sure that a lot of the column hardware, steering shaft, and horn parts probably would interchange.
I realise I'm reviving an old thread here, but was wondering if you got to bottom of this problem? I have a '68 and it has the same problem - play in the column, the wheel can move 1/2" either way before the shaft in the engine bay responds. What does it require to rebuild this?
No luck unfortunately. I ended up buying a refurbished column which didn't really help much. Took it to a corvette specialist who adjusted my steering box and fixed the issue for a few weeks before it reappeared. Ended up getting sick of how much money I was spending to try and make it drivable so sold it and got a bmw z4. I miss the engine sound though!
We would need to know what type of steering you have to be of any real help. The only suggestion I have right now is to have a friend slowly rock the steer wheel back and forth while you watch the linkage for play. There shouldn't be any play anywhere. When 1 part moves the next should move instantly. T
Pretty reasonable C3 job I thought, I rebuilt my 68, early November build, telescoping steering column. I bought my bearings from Corvette Central. Call them to make sure you get the right ones. Not sure why you have the slop in the column, I would pull it out, disassemble, find the problem and rebuild it.
Jim Shea has some excellent papers on how to rebuild the 68 column.
What I'm hearing is that I need to pull the column and possibly replace. Bummer. The column is a NON- Tele/tilt so it would appear the slop is in the splines (as mentioned the wheel can be rocked 1/2" either way without any movement at the other end of the shaft). Time to search for said papers from Jim!
