I'm in the process of removing rear suspension on my 75. Left side trailing arm off car now. Bushing is completely shot but my big question is how can I tell if bearing is in need of replacement? I do believe it is original to car but there doesn't seem to have any play one way or the other. When I turn the hub I hear no noise to speak of but it just seems like more of a resistance feel. Thanks in advance for any input on this.
since you already have the arm out and appear to intend to remove the other why wouldnt you disassemble the bearings to replace them.
Well I am going to replace them,it's just that years ago I had an alignment shop tell me they couldn't do rear alignment because rear wheel bearings were bad, but I don't think they are. Maybe dried up grease but probably not bad. Yep, gonna order me two from Vansteel
I am going to be pulling my arms off to replace the bushings but I was not planning on messing with the bearings because my rotors still have the rivets in place. From what I have read is you do not want to drill out the rivets because then you will have to worry about run out issues.
There is no need to remove the rotor from the spindle when servicing the bearings. It's easier to leave it place actually.
The bearings should be inspected every 30-40K miles.
Then I will be sure to check them. Is there a way to replace the emergency brake shoes without drilling the rivets? I don't see how there would be but then again I was thinking you needed to do so to change the bearings.
You cannt mark the rotor and than as it is pulled off mark the axle stub so it goes back on in the same position? Cannt see replacing brake shoes without removing rotor. They are inside the rotor.
Pull the spindle and rotor as a single piece. Rebuild parking brake. Inspect/replace bearings. Reassemble.
Keep in mind that inspecting or replacing the Bearings is not at all like the Fronts. It requires special Tools and the know how to do it. That is why people like Van Steel and others offer rebuilding service and exchange service. If You feel that what You have is OK You may want to just Grease them and leave them be. There is a Greasing adapter available to force some grease in there. There is also a way to install a Zerk. However both methods are best used for peace of mind, as it is highly doubtful that any of the new grease will actually find a Bearing. If You want every thing new, then complete rebuilt Trailing Arms are available, but you will spend a lot on shipping two directions. The Bearing assemblies are not that difficult to remove from the Arms.
Rotors were drilled out way before I got car. I am just unsure if bearings have any problems at all, and if not I could just replace trailing arm bushings and clean up arms , but I think I'll just send them off and get them refurbed
