'74 with No Cats
Old Jan 14, 2015 | 11:21 AM
MBrianB's Avatar
MBrianB
Default '74 with No Cats
I have a new to me '74 vert. It does not have any cats in the exhaust.
What changes should be made to bypass the O2 sensors in the system?
Any other changes or settings I should check to make the car run right?
Old Jan 14, 2015 | 11:25 AM
JimLentz's Avatar
JimLentz
Why does it have O2 sensors? Was the carb replaced with some sort of fuel injection?
Old Jan 14, 2015 | 11:35 AM
gmtech1234's Avatar
gmtech1234
Cars did not have cats until 1975.
Old Jan 14, 2015 | 11:39 AM
MBrianB's Avatar
MBrianB
I'm used to newer cars so I thought that there were O2 sensors used with cats. When I looked at exhaust systems for the '74 there appeared to be the openings for O2 sensors on the pipes.
There are also some gundgy wires taped together in the area O2 sensors might have been located. Puzzling out all the changes and 'upgrades" made by PO's on a 41 year old vette are certainly challenging.
Old Jan 14, 2015 | 11:45 AM
Mike Ward's Avatar
Mike Ward
I think you need to educate yourself properly on pre-computerized, pre-EFI, pre-HEI cars and stop assuming.
Old Jan 14, 2015 | 11:51 AM
MBrianB's Avatar
MBrianB
Thanks Mike, That is what I am doing. That is why I come and ask questions. I am new to corvettes and new to GM vehicles. I did build custom 4X4's at my own shop but that was in the early '70's. Later I build and restored '53-'56 Ford trucks. Bear with me as I am a quick learner.
Old Jan 14, 2015 | 01:57 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by MBrianB
...When I looked at exhaust systems for the '74 there appeared to be the openings for O2 sensors on the pipes...
Where were you looking? 74s were the last C3s with dual exhaust and no cats. No cats; no O2 fittings.
...There are also some gundgy wires taped together in the area O2 sensors might have been located...
You'll have to post a pic of your "gundgy wires".
Old Jan 14, 2015 | 02:19 PM
MrJlr's Avatar
MrJlr
If you were working on cars and trucks since the early 70's, you should already know this.
You're confusing us.
Old Jan 14, 2015 | 09:47 PM
MBrianB's Avatar
MBrianB
I closed my shop in late '71 and went to work for a local water company. I did not get back to working on cars again until '83 and then I bought a '63 Lincoln Continental Convertible. I never really wrenched on the post '75 cars.
and Mike, the pictures of C3 exhaust with O2 bungs was online as some parts houses, probably was a stock picture they used for all the C3 exhaust listings.
Old Jan 14, 2015 | 09:50 PM
Patro46's Avatar
Patro46
Your the lucky owner of the last year Corvette before Ralph Nader was fully inserted up your tailpipe!
Old Jan 14, 2015 | 10:14 PM
gbvette62's Avatar
gbvette62
You may have been looking at a generic picture, or you could have been confusing the air tube used in some systems, for the O2 fitting. 75 and later Corvettes with an emission system using an A.I.R. pump, have an air tube installed in the forward "Y" pipe.
A small portion of 80 Corvettes made for sale in California, were the first Corvettes that used an oxygen sensor. From 81 on, all Corvettes had O2 sensors.
Old Jan 14, 2015 | 10:15 PM
7t9l82's Avatar
7t9l82
I'm confused, worked on old cars doesn't understand old cars. i heard the term " Ford" mentioned, that may explain it.
Good luck on your project.
Mike Ward's Avatar
Mike Ward
What you are looking at is probably the AIR injection ports. Four per manifold. Not O2 bungs.
Old Jan 15, 2015 | 06:15 PM
LS4 PILOT's Avatar
LS4 PILOT
My wife bought a 1985 Mustang GT w 5 liter. HO brand new back then. That weekend , I sawed out the cat converter , took it down the road to the local bubba exhaust shop. Oh look Billy JOE ..... My converter fell off ......what to do? How about I fix ya up with a dual exhaust ....... Really? lol. ....
Stopped by the local speed shop they Doctored on that little Holly carb a tad . The good ol boys mumbled a few words , couldn't understand a word , they knew exactly what they were doing. As they raced at the local track every weekend.
Ran like a stripped ape......( Carter you know how fast that is !)
To '74 with No Cats
