AFR power
Old Jan 17, 2015 | 06:58 AM
c3_dk's Avatar
c3_dk
Default AFR power
http://www.dragzine.com/news/jim-bar...r-245cc-heads/
Old Jan 17, 2015 | 04:52 PM
Solid LT1's Avatar
Solid LT1
Did you read the part about them being on a 464cu/in tall deck small block? Nice heads if your motor can use them, most forum members wont be able to use them.....Or maybe I'm wrong as I tend to go on the small side when it comes to port volumes on my builds. My low 12 second 355 motor had 175cc intakes and a 650 Holley on it and I'm sure none of these parts would be recommended by most forum " experts " for a low 12 second car running 118MPH trap speeds.
Old Jan 17, 2015 | 06:26 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
The car body is a C4 that's about as far as I would go. It is a track prepped Ford 9 inch rear end 1/4 mile race car and should be in the low 9's for something to brag about.
Old Jan 17, 2015 | 06:52 PM
d555's Avatar
d555
7000 ft elevation...some times 8500 DA... Wonder what the nitrous plate is adding?
Nice heads thou...
Dave
Old Jan 17, 2015 | 08:16 PM
tektrans's Avatar
tektrans
I would agree if not for the 7000+DA.
Old Jan 18, 2015 | 09:12 PM
7t9l82's Avatar
7t9l82
the altitude correction factor would change things. N.H.R.A has a chart.
Old Jan 19, 2015 | 11:55 AM
bluedawg's Avatar
bluedawg
There is also several correction calculators on the web, dragvette & wallace racing are a couple to name a few.
To AFR power
