82 Yoke
Old Jan 19, 2015 | 11:06 AM
tltw72's Avatar
tltw72
Default 82 Yoke
Do the 82 diff side yokes have the same dimension (.187) from the snap ring to the end as the older ones?
Old Jan 19, 2015 | 11:38 AM
Gale Banks 80''s Avatar
Gale Banks 80'
The 80 to 82 Vettes use a Dana 44 which has a Yoke of its own. There are Two different ones Yours should use the larger Spicer 1350 U-Joints but You should find out before ordering a replacement. It should use 5/16" bolts to hold the U-Joint straps. Generally clearances are measured between the Shaft and the Yoke to measure wear, and not from the Snap ring Grove to the end of the Yoke. So in answer to Your question, I don't know.
