a/c heater box help
Old Jan 19, 2015 | 11:32 AM
73silververt's Avatar
73silververt
Default a/c heater box help
i don't think this valve/bracket or linkage should be bent, correct? Located at behind lower right kick panel, in their off positions, will the door on heater core bracket be closed, as well as the other 2 doors pictured in heater box and extension that is attached (I'm guessing that's for vent direction. Has anyone repaired the door at vent opening, behind lower rt kick panel, all the rubber is gone around the edge, that seals
Old Jan 20, 2015 | 07:24 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
It's bent for sure and should be horizontal to the car when installed. If you try to straighten this out it will probably break... if it does I believe I have used left in stock that will fix you up. I'd have to check tomorrow.
In regards to the door itself, you just drill out the old rivets and separate the two halves, then insert a new seal and re-rivet it. Here is a kit that will do it all for you, it's pretty simple.
http://willcoxcorvette.com/product_i...oducts_id=6833
Willcox
Old Jan 20, 2015 | 07:41 PM
73silververt
Willcox
car was hit on that side, so I figured valve was damaged, will try and pm you.
Old Jan 21, 2015 | 08:11 AM
0Willcox Corvette
Former Vendor
Email me at Support@Willcoxcorvette.com
Old Jan 21, 2015 | 09:30 AM
73silververt
How bout those doors, what position would they be in when system Is off, temp lever in cold position?
Old Jan 22, 2015 | 12:18 PM
0Willcox Corvette
Former Vendor
Here is the pod you need. http://willcoxcorvette.com/product_i...ducts_id=28404
doors should be closed.
To a/c heater box help
