Clutch Question
Old Jan 24, 2015 | 06:38 PM
jordan89's Avatar
jordan89
Default Clutch Question
Well guys, I'm in the market for a new clutch for my '74, and want to double check so that I get the right one the first time. I'm looking at the McLeod 75224 clutch:
http://www.jegs.com/i/McLeod/673/75224/10002/-1
My question is, will this work for a Muncie M21 tranny? Just want to double check that it will because I'm looking into placing an order tonight.
Thanks in advance!
Old Jan 24, 2015 | 08:04 PM
Solid LT1's Avatar
Solid LT1
74 Corvettes came with a Borg Warner T-10 trans which is 26 spline, that clutch is for an older 10 spline Muncie. Muncie 4 speeds were 10 spline until 1970 then starting in 1971 they too were 26 spline input shaft, do you know if your trans was a 10 or 26 spline input? You might be able to determine this by looking into the fork opening of the bellhousing.....the 10 spline will be about an 1/8" wide tooth where the 26 spline will be under 1/16". I like Centerforce clutches myself
Old Jan 24, 2015 | 10:50 PM
jordan89's Avatar
jordan89
It's actually an M21 tranny. I got under the car and checked when I first got it. I thought the newer C3 Vettes were the ones with the T10s? I'm not sure about the splines. I would actually have to try to get under there and look. I didn't know they switched input shafts on the M21. Good to know.
Old Jan 24, 2015 | 11:36 PM
1974ta's Avatar
1974ta
Default Clutch
Later M21s also had 26 spline input shafts too. Why not go with OEM like LUK and save some money?
They include a non magnetic pilot bushing with their kit too.
Bill
Old Jan 24, 2015 | 11:49 PM
jordan89's Avatar
jordan89
Well, after doing a bit more research it looks like for the late 74s they switched to the t10. I have an early 74 Vette, and it's starting to look more like a 26 spline input shaft. I was under the impression that all M21's had the 10 spline input shafts. I learned something new today.
Bill, the reason why I can't go with an OE clutch kit is because this will actually be used on an LSX engine. I'm mating the old M21 to the LSX engine.
Old Jan 24, 2015 | 11:52 PM
jordan89's Avatar
jordan89
It looks like this would be the clutch for me?
http://m.summitracing.com/parts/mcl-75221
To Clutch Question
