New Rag joint
My question is the rag joint. From the searches of done here, replacements are not quite the quality units the GM rag joints were.
I usually use Guldstrand parts, ZIP and Paragon with much success in the past. Anyone know a quality rag joint? I can call a few places and see where they are made. Any helpful advise appreciated.
http://www.guldstrand.com/scripts/pr...?idproduct=134 is one I was considering.
The Gulstrand flexible coupling assembly shown in the earlier posting has a 3/4 inch diameter, full round, 36 spline "bowtie" flange so would be for the earlier Corvette gears. It appears to be an original GM part.
Flexible coupling assemblies for the 1967 thru early 1969 were original GM part numbers 5699250 or 7806391.
Flexible coupling assemblies for 1969 late thru 1982 were 7808553, 7813351, & 7818568.
You may note that the original GM flexible coupling discs are constructed of 7 alternate layers of neoprene rubber and cotton cloth and are 3/8 inch thick. These discs are quite stiff and provide good road feel.
(FYI) Passenger cars with power steering had flexible coupling discs that were the same 3/8 inch thick but had only 4 layers of rubber and cloth. With the extra rubber between layers, these discs were rather soft but provided superior isolation so as to prevent hydraulic noise from the power steering system from coming directly up the steering column and into the driver compartment.
Hope you have luck finding the original (OEM) assemblies because they will undoubtedly be of better quality and most likely stiffer than off-shore parts.
Jim
Also, to a point Jim made in his last sentence:
“Hope you have luck finding the original (OEM) assemblies because they will undoubtedly be of better quality and most likely stiffer than off-shore parts.”
I call Guldstrand, ZIP and Paragon. Both admitted they had the part, they could sell me the part, but it was made in China and that I may want to consider NOS instead. I have to admire that type honesty and professionalism.
First of all, what type input shaft do you have on your steering gear. Do you have the theoretical 36 spline, full round 3/4 inch input shaft? Or do you have the theoretical 30 spline, 3/4 inch input shaft with the flat?
It is important because you should try to have the correct flexible coupling assembly with the correct mating splines to fit your gear input shaft.
Here is one sceneario:
You just will not be able to install the coupling assembly with the bowtie that has a flat onto the earlier full round input shaft. You might be able to "hog out" the flat in the bowtie with a speed grinder and force it onto the full round input shaft. Or possibly mill a flat on the input shaft. You will not have matching splines so I don't know if things can be forced or not.
I really hate to describe forcing things together, particularly when we are talking about a critical function like steering your car.
The flexible coupling assembly part numbers that I referenced were the GM part numbers for the OEM parts. I do not have anything to cross reference the part numbers that you sight. As I mentioned earlier, the Gulfstran flex coupling assembly picture has a full round, 36 spline, 3/4 inch dia bowtie flange.
Jim
I ask this question because the original poster showed interest in a coupler that was removed from a 69 BB with P/S.
The numbers read (as best as I can tell) are 7807063. Below that row there is a circle with a "K" in the center followed by a "W". It has a 3/4" input shaft with 16 splines (with the cinch bolt at the bottom) going from 8 o'clock to 1 o'clock. the output shaft is 1" and has 20 splines going from 9:30 to 2:30 o'clock. There are no flats. It has a copper connector in the center. It has 7 layers in the fabric area.
What is this?
Jeff
Jim
What is the difference between Flexible coupling assemblies GM part numbers 5699250 or 7806391? Is one power steering and one non power?
One distinguishing feature on your assembly is the extended heads on the two shoulder bolts. Here is a drawing of one of the bolts.
Also your original flexible coupling assembly has the brass ground strap connecting adjacent quadrants so as to complete the horn ground circuit. Service flexible coupling assemblies (manufactured after 197O) did not have a ground strap but had a coupling disc with wire screening molded into one face. This screening provided the ground path for the horn.
So other than the extended head bolts the two parts look the same and would function the same.
Jim
