Made a Few passes last night
Old Jan 31, 2015 | 11:36 AM
holley505's Avatar
holley505
Default Made a Few passes last night
Pass at the track...
1.612 60ft not my best but decent.
https://www.facebook.com/video.php?v...type=2&theater
Old Jan 31, 2015 | 11:54 AM
tektrans's Avatar
tektrans
Awesome. Better 60' and you're in the 10's.
Whats the set up?
Old Jan 31, 2015 | 01:47 PM
Les's Avatar
Les
That's flyin'! Soooo close to hitting the 10's. It's there, waiting for you.
Old Jan 31, 2015 | 04:12 PM
76Rat's Avatar
76Rat
Nice run! Missed it by this much!
Old Jan 31, 2015 | 06:33 PM
BKbroiler's Avatar
BKbroiler
Nice run. What tires and converter are you using?
Old Jan 31, 2015 | 07:00 PM
7t9l82's Avatar
7t9l82
movin ! I just put an FTI convertor in mine so i will head out there as soon as i get some drag radials on.
Old Jan 31, 2015 | 08:36 PM
gjohnson's Avatar
gjohnson
How about a pic of your car?
Old Jan 31, 2015 | 10:09 PM
7t9l82's Avatar
7t9l82
who's?
Old Feb 1, 2015 | 01:57 PM
ajrothm's Avatar
ajrothm
Nice pass! You're a 60' away from 10s. Nice mph too.
Isn't that just a cammed LS3?
Looks strong!
My buddy's C6 grand sport with a cam only LS3 also ran 11.0@126 in good air.
Old Feb 1, 2015 | 03:08 PM
Red 69's Avatar
Red 69
Hey-Sean, long time no see. Last I saw you at OSW, I believe you had just installed AFR heads or LS3 cam. It is good to know you are still having fun with the white shark.
Old Feb 1, 2015 | 05:05 PM
holley505's Avatar
holley505
Thanks Guys... I have run 10s before... when the 60 dips below 1.6 I have hit it a few times.... with a mph of 125
I run a 3500 stall with 275/60 15s M/T and 3.36 factory rear highway gears and T400. My set up is a 418 LS3 with 4 inch stroke bottom end from TEXAS SPEED 2008 AL block....with small Cathedral AFR 205 mongoose heads (Small Heads LOL) VIC JR intake AED CARB 246/256 cam with 112 LSA
see my sig for best time...
Old Feb 1, 2015 | 05:06 PM
holley505's Avatar
holley505
Whats up buddy... my first time back to the track in over a year.
Funny thing is I can run the 1/4 in 2nd gear... I can shift or hold it ... I was short shifting second. I still don't have the vacuum to hit 3rd at high RPM... I am sure the car can go 10.60s+ with a vacuum pump so I can shift into 3rd at high RPM
See this 10.90 pass... only to second gear. Notice MPH is lower because I couldn't get 3rd
Old Feb 2, 2015 | 12:11 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Very impressive! You're almost there!
JIM
Old Feb 2, 2015 | 06:04 AM
ajrothm's Avatar
ajrothm
I'm not following you on the vacuum/shifting thing?
Are you saying the trans won't shift to 3rd at wot? If so, that has nothing to do with vacuum. Vacuum modulators only control part throttle shifting. You have something else going on if it's not shifting to 3rd at wot. (Governor, valve body, bands/clutches).
Maybe I'm missing something...(I probably am..)
Old Feb 2, 2015 | 06:21 AM
Robert Thomas's Avatar
Robert Thomas
Army Hoist Operator
Is that black bulge bonded to the hood? Do you have more pictures of how it's intalled?
Old Feb 2, 2015 | 07:05 AM
63split63's Avatar
63split63
Default I Made A Few Passes Last Night Too !
No luck this time .
Old Feb 2, 2015 | 09:11 AM
holley505's Avatar
holley505
Yeah... cant figure it out. Maybe Vacuum...maybe not. each time I get it tested its part throttle and works fine. at WOT typically it will not go into 3rd unless I shifter super early like before 4k and that only sometimes. Maybe I need another trans.
To Made a Few passes last night
Old Feb 2, 2015 | 09:13 AM
holley505's Avatar
holley505
The hood is a L88 that was cut and 1inch of glass added to raise the hood to clear my intake.
Old Feb 2, 2015 | 09:35 AM
ajrothm's Avatar
ajrothm
What trans? T400?
Wot shifts are controlled by the governor and changes made in the valve body. If the valve body has been modded for manual shifts, it will over ride the governor...if that's the case, then there is an issue with the valve body or the 2-3 shift components themselves. (Clutches/band/servo).
Does the fluid smell burned?
Sometimes if you let off the throttle and it shifts to 3rd with less load, that means the clutches/band is going out I believe.
Old Feb 2, 2015 | 10:41 AM
holley505's Avatar
holley505
What trans? T400?
Yeah, this sounds like this issue exactly.
