Took My Air Filter Off....Now Problems?
Old Aug 8, 2002 | 11:44 AM
bsowa's Avatar
bsowa
Default Took My Air Filter Off....Now Problems?
The other night I took the Air Filter Unit off just to look at the carb and choke, etc. Didn't touch anything or adjust any screws. After I put it back on my idle went from 600-700 RPMS to 1000-1100 RPMs. What could I have possible done. Then this morning I ran to Target and back. when I got home and shut off the engine, it stayed "running" for about another 15 seconds. Any ideas what I could have done and how I can fix it? Thanks... :confused:
Old Aug 8, 2002 | 11:51 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Took My Air Filter Off....Now Problems? (bsowa)
sounds like the air filter is hitting something and causing a bind.
Take it off again and look for interference
Old Aug 8, 2002 | 11:57 AM
rreavis's Avatar
rreavis
Take the Air Filter back of and crank the car. See if it does it with it off.. If not, like he said, something is binding. :smash:
Old Aug 8, 2002 | 12:09 PM
bsowa's Avatar
bsowa
Default Re: Took My Air Filter Off....Now Problems? (rreavis)
Ok....did that and it is back to 600 RPMs, and shut right off....is 600 low for a 4 speed manual? I really need a tune up....nervous about trying it myslef....
Old Aug 8, 2002 | 12:14 PM
rreavis's Avatar
rreavis
Sounds like you were binding up on your Choke linkage. Be carefull with that when you put it back on. As for the idle, 600 is not a really low idle. It is documented what is recommended, but that would be with Vac lines disconnected and plugged. I believe in Tune-ups... Plugs are cheap compared to the price of Gas. But if you do not know what you are doing, might want to have someone there that does to keep you honest and riding again in short order.
Old Aug 8, 2002 | 02:38 PM
joe74's Avatar
joe74
You have an idle stop solenoid on the car? If so, you may have done something, loose connection or ????. If it kept running after turn off it may be the solenoid isn't releasing like it's supposed to.
Old Aug 8, 2002 | 02:49 PM
FeedVaal's Avatar
FeedVaal
Default Re: Took My Air Filter Off....Now Problems? (joe74)
QUOTE]You have an idle stop solenoid on the car? If so, you may have done something, loose connection or ????. If it kept running after turn off it may be the solenoid isn't releasing like it's supposed to.
[/QUOTE]
I think the choke rod needs a little shot of WD/40. Run on is common with a rich idle condition.600 idle is about right after the choke kicks out.[
Old Aug 8, 2002 | 04:29 PM
bsowa's Avatar
bsowa
Default Re: Took My Air Filter Off....Now Problems? (FeedVaal)
They other thing is my front choke tube is still broken at the manifold.....Zip's has it backordered for me...
Old Aug 8, 2002 | 05:13 PM
page62's Avatar
page62
Change to an electric choke -- costs about 35-40 bucks. They work much better than hot water or hot air chokes. :smash:
Old Aug 8, 2002 | 05:25 PM
bsowa's Avatar
bsowa
Default Re: Took My Air Filter Off....Now Problems? (page62)
will an eletric choke take care of this:
Anyone have a pic of an electric choke??
Old Aug 8, 2002 | 05:52 PM
killain's Avatar
killain
Oldtimer
Did you leave the vacume hoses off? :yesnod:
Old Aug 8, 2002 | 05:56 PM
bsowa's Avatar
bsowa
Default Re: Took My Air Filter Off....Now Problems? (killain)
Nope....replaced them....think it was binding up somewhere....
Now about that electric choke....Daily Driver told me to egt it awhile ago....is it very hard to instal..
Ultimate newbie here....
Old Aug 8, 2002 | 06:12 PM
Steve Grodin's Avatar
Steve Grodin
Electric chokes are great, but if you have to pass smog and car didn't come with electric choke may have a problem passing visual.
To Took My Air Filter Off....Now Problems?
