The Forty Eight Hour Corvette
The 48 Hour Corvette will be Equipped with our RideTech Level 3 Coilover system
Front Suspension Features:
Tubular StrongArms for optimized strength and proper alignment
Taller RideTech spindles optimizing camber gain for better handling
Billet steering arms eliminate bump steer and optimize Ackerman angles
Tru Turn steering linkage for proper steering geometry
StrongArms feature Integrated Caster Slugs for easy alignment
Delrin control arm bushings offer stable, smooth, and quiet bushing movement
Rear MuscleBar keeps the car flat with added tuning adjustable link mounts
TQ Series Mono-Tube Coil-Overs add tunability and improve ride and handling on the street and track.
Rear Suspension Features:
Tubular cross-member allows easy rear end removal and improves strength
Offset fabricated trailing arms offer more tire clearance and increased strength and durability
Relocated camber links optimize camber gain for better handling
Rear MuscleBar keeps the car flat with added tuning at adjustable link mounts
Falken Tire will be the official tire of RideTech 48 Hour Corvette
We will be using the AZENIS RT615K TIRE its is a Street-Legal Motorsports Performance and a DOT-Approved Track Tire
Looking forward to seeing the car at Good-Guys Texas - should be done by then right? Also, the USCA event at TMS. Maybe you'd like another test car for the Texas GG events and USCA at TMS?
Gary
Gary
The 48 Hour Corvette will be done before both events. As of right now we are scheduled for both events as well. More test cars are always a plus!
Brian
Most of the parts suppliers are coming to install their own particular parts on the car and we have a build crew of our guys currently that will be doing our stuff. We have had a decent amount of interest from guys like you that want to come up though, so let me check into it and see what I can do!
Chase
I look forward to meeting you!
We have the primary build team all set, but the Corvette build is open to spectators. I would encourage anyone to come up and take pictures to post on the forums. We can use all the extra exposure we can get! We will have several manufacturers here as well...it might be a good time to pick their brain on your corvette questions. For those who can't make it, we will be running a live chat during the webcast...chime in there with your comments and questions...the more the merrier!
#33
#34
#38
Put them on top of the pump...look at some of the LS swap threads on the forum for help...your not building a Fbody or Abody here....much tighter in that area
I'm also looking forward to your solution to the interference of the LS7 dry sump pan to the steering centerlink.....based on my mock-up in my 72 Vette, I don't see how the Ridetech centerlink is going to work with that particular oil pan......we will see...
#39
FWEIW; The Stainless Steel Brake Corporation aluminum billet MC for a C3 is over $400.
Aside from weight, the stock AC Delco MC is cast iron and it'll rust. You can paint it, but if normal brake fluid spills on the paint, it'll take the paint off. I have a painted Delco MC on my 68, but I have silicon brake fluid so the paint is protected.
#40
http://www.ridetech.com/48hourcorvette/build-recipe/
