Carb showdown...which to go with?
I got Cliffs book on the q-jet and learned by doing.
So now whenever I make any change to the engine or intake or exhaust or altitude or temp I can tune the q-jet accordingly.
I'll admit, like any sensitive piece of equipment the q-jet is finicky in it's adjustments to get it just right. Once there however it performs very very well.
The q-jet has it's inharent weakness' as anything does and addressing them sooner rather than later will save a lot of futzing around later on.
I run a cam with 14" of vacuum at 800rpm and down to 10" in gear or lower. The q-jet needed more bypass air to do this well, but so would any carb to do it well.
The 76 through 79 q-jet would be the one of my choosing as it has the APT adjustment which is very useful. I run mine with no choke and it runs great just like that since I only run it in warmer weather anyhow.
So whatever you go with, you will have to become the expert on that carb if you want to run it at peak performance.
With my 377HP 350 I get 19 MPG in combined driving and 22MPG on the highway, TH350 trans 2600 stall converter with a 3.08 rear, 27" tires.
Given I had to say one way or the other, there are likely more people using holleys, therefore it is more likely you will find someone who has a clue in regards to the Holley vs the Q-jet.
That would make a q-jet person's skill set more rare and potentially more valuable, also less needed though.
Just get a 750...and do the step up springs and metering rods/jets as needed.
I had a 650 AVS on my 327 and it was a rock solid performer....but it took me a whole day to jet it!
Ran it for 5 years.....
Q-Jets are great too.....but hard to find one not wore out.
The Holley 3310 is a wonderful unit as well......very forgiving on a mild Big Block.
The key is to get what you feel comfortable jetting.
Edelbrocks can be tuned with out pulling the lid off in most cases....
Holleys make a mess but I love them.......a moroso drain cup is a great tool...
Although you made not need 750cfm....a 750 cfm carb will come jetted much closer than a smaller counterpart.
Keep us informed on what you decide
Jebby
So no one need agree with me on what I have gathered, so please do not take offense.
The Qjet is a very complex carb, while people have made it perform well in higher performance than stock applications it comes at several prices.
On cruisers that get romped on here or there they seem to do very well, I also see that too many people relay on a tech to set it up and get it close to right, and would be lost if that tech closed his doors, ( yes, more than one qjet guru out there )
I would be in that boat, I love to learn about the things I work on/with I can tune dual/multi webers something that scares some people, but the fact is that came at years of learning, I would have to spend that time learning the Qjet, I simply do not want to invest the time in a carb that while I do believe it can work well I believe it has built in short comings I do not want to deal with, it's too cantankerous for me at this time.
My car has a 650 Edelbrock on it, and after sitting close to or over 3 years it will need a rebuild if the tripe in todays gas didn't ruin it from sitting,
I might play a bit more with it but after reading more on that Holley 3310 750 I would like to try it, it seems to be a very popular carb and very forgiving and far more user friendly than the qjet
I come from a time when everyone over carbbed over cammed and the cars went percolating like a gagging goldfish in and out of the cruise spot,
I didn't want that and picked the 650 thinking it would be fine on my 454 but then I got guys telling me it's not big enough, so back when I was testing it and putzing with it, from a stop it would take off hard, if I didn't let up it would melt the 275 60's, it would climb well but if at cruise speed and you floored it, it seemed to have a dead spot that would last about a second then take off, I busted that rear strut and that is where testing stopped, the car hopefully will be back from the frame swap out very soon, and yes, I have no problem rebuilding the edelbrock I have rebuilt several, piece of cake to work with.
If youre sticking to a real tight budget, you can get the Holley #3310 aluminum body carb (the polished looking one) for around $300 shipped if you shop around. I have one of these on a mild 454 with a performer intake and old school comp 270H cam and it runs excellent. The one I just bought was a #3310-C which is the old green colored dichromate finish that I wanted for a stock appearing build.
You can always pick up a swap meet carb and rebuild it but...Honestly, I am not big on used carbs..I find they tend to always have some issue that a normal rebuild does not solve. I typically start out with a new carb and then rebuild them myself as need through the years.
Holleys are very easy work on, basic parts/gaskets are in stock at every O Reilys/Auto Zone around and you can literally pull the fueling components apart on one on the side of the road in 10 mins.
Between my dad's cars and mine, we own 7 Holley carbs on current running cars, I maintain/tune them all, and I would never run anything else.
I have had Quadrajets as well, some were good, some where terribly problematic...all of them were hard to work on and pretty finicky/inconsistent at best... I do still have one on a 350/270hp engine that is not in a car that ran pretty well for several years...However I never saw the "great gas mileage" that people claim for Q jets. it got 10-12 mpg just like the holleys.
For a mild 454, a #3310 will bolt on and go, you usually don't even have to set the float levels...Just bolt it on, hook up your linkage/vacuum stuff, adjust your idle mixture screws and idle speed screw, and forget about it for 20 years.
As I have said many times before, the Qjet is good carb when it operates correctly but it was GM's attempt to stave off the advent of mechanical/electronic fuel injection in the late 60's/70's/and early 80's by attempting to precisely meter fuel through a carb in the hopes of better fuel mileage, drivability, versatility, and lower emissions. The Qjet is overly complicated for what a carb needs to do and can be problematic when things go wrong, being kind.
Everything Ajrothm said about the vacuum secondary Holley's is true-reliable, easy to tune, easy to rebuild, etc. I have had a Holley 4175 650 CFM vacuum secondary Qjet replacement carb on my 78 L-82 since 1985 and the Holley has been dead reliable, same gas mileage as the Qjet, and easy to tune. I went up 4 primary jet sizes on the Holley 4175 this past spring with the newly rebuilt 355 L-82 425 HP engine and the carb did not even hiccup with the engine upgrade-amazing….
I just don't see this fascination with the Qjet……except that it is the carb that many C3's came from the factory with but the best??? very debatable..
This replaced my Holley 4165 spreadbore that flooded out and killed the engine whenever I hit the brakes hard.
Do you plan on running it on the autocross track? Do you plan on Racing it at the drag strip? Do you plan on racing your friends at the local cruise nights? Were you planning on putting it on the Dyno to see what kind of HP you are making?
If the answer to the above questions is no then the 650 would be enough. It might not be the ideal carb for your engine but it will work and work fine.
With a little tuning you can get rid of the dead spot you mentioned. What more do you want?
I know circle track guys putting out a lot more HP than you and are running a carb almost half the size that you have.
Ive used a few edlebrocks no complaints. But couldn't figure out what the problem was when the one on my sisters 69 impala went bad.
Holly, had a few never had a problem that couldn't be fixed with hand tools and some time.
For fun factor my fave was a 650 mechanical secondary. Had that in my 72 chevelle.
Something about feeling the secondary open through the pedal. Akin to slamming through the gears with a manual trans even though nowadays an auto can be setup to run just as good if not better.
