alarm switch
Old Feb 7, 2015 | 06:00 PM
ray3222's Avatar
ray3222
Default alarm switch
I am in need of a anti-theft alarm switch for a 1972. I have tried (6) corvette catalogs, chevy parts, etc. to no avail.
Can anyone help?
Thanks in advance.
RAY
Old Feb 7, 2015 | 08:07 PM
sullyman56's Avatar
sullyman56
Can anyone help?
Thanks in advance.
RAY
If it takes the same switch as my 77, good luck. Mine was discontinued and I was lucky enough to find one. Cost me $ 100 too.
Old Feb 8, 2015 | 12:21 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Can anyone help?
Thanks in advance.
RAY
The switch was discontinued around a year ago... Finding one is not very easy right now. You might go the parts/sale section and start a WTB alarm switch thread.
Willcox
Old Feb 8, 2015 | 12:47 PM
GUSTO14's Avatar
GUSTO14
Can anyone help?
Thanks in advance.
RAY
Ray, can you post a picture of the exact one you need? I have a number of these switches I've accumulated over the years (I typically would buy two or three each time as they were often fragile). Unfortunately there were so many different ones produced, it gets confusing which switch exactly you may need. I've seen two or more different switches installed on the same year car. (Many folks took what they found and adapted them over the years.)
Good luck... GUSTO
Old Feb 8, 2015 | 09:56 PM
ray3222's Avatar
ray3222
2 photos added. One terminal is missing. Send price if you have switch w/ key. Thanks.
Good luck... GUSTO
Old Feb 9, 2015 | 01:21 AM
BLUE1972's Avatar
BLUE1972
You can try:
NKK SWITCHES CKL12BFW01 SWITCH, KEY OPERATED, SPDT, 3A, 250VAC, good website.
Last year I got one from ALLELECTRIC for my 1980 truck. The key was a flat blade double sided. I did not see it in the last catalogue.
hope this helps.
Old Feb 9, 2015 | 01:23 AM
BLUE1972's Avatar
BLUE1972
www.newark.com
MULTICOMP S216R KEYSWITCH, SPDT, 2POS, RDM, 2KEYPULL
Also very close to the factory.
Old Feb 9, 2015 | 07:07 AM
GUSTO14's Avatar
GUSTO14
I must apologize Ray, I thought you were looking for the door post switch. It appears (based on others comments) you are looking for the keyed switch that arms or disarms the alarm. If that is the case, I don't have any of them.
Good luck... GUSTO
Old Feb 9, 2015 | 12:25 PM
robert.sperry's Avatar
robert.sperry
The alarm switch internal contacts are brass and as the switch ages, the brass oxidizes and eventually the switch stops working. I was able to save the alarm switches on my own 74' and on my sons's 74' by soaking the removed switch in a glass filled with a fluid composed of 2 parts ammonia to 1 part hydrogen peroxide. I let it sit about 20 minutes in the fluid, rinsed it in water and blew the switch out as best possible with my air compressor. You can check the switch at any point to see if the contacts are clean with a VOM (volt/ohmmeter).
If you want to try out this fluid mixture first, find an old oxidized brass bolt nut or washer and put it in the fluid and you will be amazed how quickly it will turn to a shiny bright brass color.
Old Feb 9, 2015 | 09:46 PM
BarryB72's Avatar
BarryB72
What about this? You get a matching set of locks with the correct 72 D code key.
http://www.ebay.com/itm/161348309277...84.m1555.l2649
Old Feb 10, 2015 | 12:41 PM
rays699's Avatar
rays699
Default alarm
Can anyone help?
Thanks in advance.
RAY
I got one from corvette central for my 69 vette, rear panel ray
Old Feb 11, 2015 | 12:40 AM
tpfarm's Avatar
tpfarm
I got one about a year ago from Volunteer Vette Products.
Old Feb 11, 2015 | 11:32 AM
MBrianB's Avatar
MBrianB
Default Here
Be the first one to go here:
http://www.corvettepacifica.com/prod...k-used-l70-77/
Old Feb 13, 2015 | 12:15 AM
nestor's Avatar
nestor
I recently got a NOS switch for my 69 from this guy....
Restoration Parts Outlet
860-649-2241
Old Mar 17, 2015 | 11:07 AM
Syl1953's Avatar
Syl1953
I just did the trick posted above by Robert.Sperry with ammonia and peroxide, had to soak twice but it WORKED. This website is the bomb! Thanks to all. Mark
Old Mar 22, 2015 | 03:31 PM
Msbfdx's Avatar
Msbfdx
My switch fell apart when trying to connect the proper wires (bubba struck again). Here is hoping someone produces a repro.
Old Mar 22, 2015 | 04:23 PM
MBrianB's Avatar
MBrianB
I have a switch I bought from Plasticfreak on the forum but did not end up using. $25 shipped if interested.
To alarm switch
Old Mar 22, 2015 | 05:53 PM
Msbfdx's Avatar
Msbfdx
Is this the on/off key switch or the jam switch? I need the key switch. Many thanks.
Old Mar 22, 2015 | 07:30 PM
MBrianB's Avatar
MBrianB
it is the key switch. Plasticfreak did not have the key and I don't have one either. I do have the u shaped piece that holds the switch to the body I will throw in if you need it.
Old Mar 22, 2015 | 09:06 PM
Msbfdx's Avatar
Msbfdx
Thanks for the offer. I think I will wait and check on other used alternatives. I recently located a matched set of alarm switch, glove box and spare tire lock with key. I may swallow hard and pay the ransom after I look some more.
