Flowmaster vs. Delta Flowmaster
Old Aug 8, 2002 | 06:11 PM
bsowa's Avatar
bsowa
Default Flowmaster vs. Delta Flowmaster
Any big difference?? I see they are listed for the same price....
Old Aug 8, 2002 | 06:42 PM
Leos 81's Avatar
Leos 81
Default Re: Flowmaster vs. Delta Flowmaster (bsowa)
I recently started a poll on this topic. You might want to check it out.
http://forums.corvetteforum.com/zerothread?id=358065
It appears that Delta Flow was much more popular. The major differences I'm aware of...
1. Interior resonance is greatly reduced.
2. Exterior sound is "slightly" reduced.
3. Delta Flow in most cases run about $15 each more expensive than the regular Flowmaster series.
4. In most cases Delta Flow dimensions are slightly larger than the regular Flowmaster series.
There may be some others, but those are the ones I remember off hand.
Old Aug 8, 2002 | 06:43 PM
82dukman's Avatar
82dukman
Flowmasters are 2 chamber while Deltsflows are 3 chamber. The regular Flowmasters are louder. With more sound comes more interior noise too!! I have DF 50's on my CE and love them. Not too much interior resonnance.
Old Aug 8, 2002 | 08:43 PM
914eener's Avatar
914eener
I've got Delta 50's with the Mid America dual exhaust (no cat) on the 81 and they sound great. Absolutely no resonance and just the right sound. Highly recommended. :) :)
Old Aug 8, 2002 | 10:49 PM
goinbroke's Avatar
goinbroke
Ok, I've got to ask a stupid question. Are flowmaster and deltaflow made by two different companies, or are the deltaflows just another version of a muffler made by flowmaster? Are the flowmaster 50s and deltaflow 50s the same muffler?
:confused:
Old Aug 8, 2002 | 11:26 PM
gearheadz's Avatar
gearheadz
Default Re: Flowmaster vs. Delta Flowmaster (rip74)
Ok, I've got to ask a stupid question. Are flowmaster and deltaflow made by two different companies, or are the deltaflows just another version of a muffler made by flowmaster? Are the flowmaster 50s and deltaflow 50s the same muffler? :confused:
Same company....the Delta Flow versions are basically the same as the regular Flowmaster mufflers except they have a row of V-shaped diverters inside that diffuse the sound waves to decrease sound level & resonance.
Mark
Old Aug 9, 2002 | 01:11 PM
Leos 81's Avatar
Leos 81
Default Re: Flowmaster vs. Delta Flowmaster (82dukman)
I believe this is incorrect. If I'm not mistaken, the Delta Flow 40s are also a two chamber muffler. It's the Series 50 and Series 50 Delta Flow that are three chamger. Can anyone else confirm?
Old Aug 9, 2002 | 08:39 PM
American Boy's Avatar
American Boy
Default Re: Flowmaster vs. Delta Flowmaster (Leos 81)
The 50 series are three chamber. That's what I had on my Camaro.
Stephan
Old Aug 9, 2002 | 09:10 PM
Darkness's Avatar
Darkness
This is true, and the deltaflows are 8 db quieter than normal ones.
Old Aug 9, 2002 | 09:25 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Both use the same type of diverters inside but the Delta's use more of them. 3 instead of 2 I think. Both mufflers are available in 2 (40 series) or 3 (50 series) chamber.
Old Aug 10, 2002 | 03:11 AM
Merlin522's Avatar
Merlin522
Default Re: Flowmaster vs. Delta Flowmaster (Vetterodder)
http://www.flowmastermufflers.com/web10/productsf5.html
Old Aug 10, 2002 | 10:29 AM
Edzred72's Avatar
Edzred72
True, but keep in mind that the 50's are harder to "tuck up under" the body. They will show from the side a little. The existing stock hanger position will not work either for the 50's are 3" longer that the 40's. Now that I have Delta 40's.. I don't like them. Way too much interior resonance, but they sound awsome from the back!!! :D :D :D
Eddie
To Flowmaster vs. Delta Flowmaster
