Engine Block VIN Decode help
Old Feb 11, 2015 | 10:32 PM
Raybee's Avatar
Raybee
Default Engine Block VIN Decode help
Can someone decode this real quick? Its a big block, not from a Vette though. That's all I know..T04020LB
Thanks!!!
Old Feb 11, 2015 | 11:48 PM
65GGvert's Avatar
65GGvert
Thanks!!!
Any chance you copied that number wrong?
Old Feb 12, 2015 | 03:04 AM
dugsgms74's Avatar
dugsgms74
The only info I can find on the LB suffix is either 1965 396 325hp w/ a powerglide or 1969 427 335hp w/ a manual trans, Unless its a CLB, then a wide variety of 71-72 396-402 engines from 210hp to 300hp
Old Feb 12, 2015 | 07:09 AM
Raybee's Avatar
Raybee
Originally Posted by dugsgms74
The only info I can find on the LB suffix is either 1965 396 325hp w/ a powerglide or 1969 427 335hp w/ a manual trans, Unless its a CLB, then a wide variety of 71-71 396-402 engines from 210hp to 300hp
Thanks - it could be CLB. This would make the most sense from what the owner is telling me.
Old Feb 13, 2015 | 12:51 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...T04020LB...
Tonawanda engine assembly plant
April 20
Check the last three characters again.
To Engine Block VIN Decode help
