Coil overs
Old Feb 17, 2015 | 06:33 AM
RETIRE15's Avatar
RETIRE15
Default Coil overs
ANYBODY USING THEM? HOW HARD ARE THEY TO PUT ON MY 74.
Old Feb 17, 2015 | 08:26 AM
CWerner's Avatar
CWerner
Front are very simple. Rear a bit more difficult but I'd say a 3 on a 5 scale.
Old Feb 17, 2015 | 11:19 AM
ddawson's Avatar
ddawson
Fronts are cake, you will spend more time removing the stock spring.
For the rear I did the Sharkbite and that took more work getting it to fit.
Old Feb 17, 2015 | 11:28 AM
RETIRE15's Avatar
RETIRE15
Originally Posted by ddawson
fronts are cake, you will spend more time removing the stock spring.
For the rear i did the sharkbite and that took more work getting it to fit.
thanx ,man
Old Feb 19, 2015 | 08:16 PM
Ranger24's Avatar
Ranger24
QA1s with my Vansteel set up, not that difficult, just time.
Old Feb 20, 2015 | 04:14 PM
Kacyc3's Avatar
Kacyc3
Any brand of coil over for the front anyone recommends more than the others or even recommendation to stay away from?
Old Feb 20, 2015 | 05:34 PM
ddawson's Avatar
ddawson
I'm using the VBP lower reinforcement puck with the Speed Direct Semi coil overs.
Old Feb 20, 2015 | 09:35 PM
l88rocket's Avatar
l88rocket
Ridetech for shocks, they are the best imo.
Old Jul 8, 2015 | 05:16 PM
Charliebates's Avatar
Charliebates
Thx for that picture DD. It sure helps.
I just ordered the Shark Bite Semi Coil Over Shock from Grady at Speed Direct and ordering the (puck) Aluminum TVL Disk part number C1-1188 as I'm typing. That part isn't on their website and so I posted the part number for anyone searching.
I chose the semi coil over shock instead the coil over because I don't feel comfortable drilling out the top shock mount hole to 3/4" to fit the Ride Tech.
The Shark Bite semi coil over uses the original coil spring pocket in the frame. That spreads the load as designed instead of creating a point loading at the top shock mount as required by the Ride Tech product.
John in Red Deer
Old Jul 8, 2015 | 07:07 PM
Richard454's Avatar
Richard454
I went w/ Vansteels- Front and rear
Front- their A-arms and coil overs- no problem to install- just basically a bolt on
Rear- I had the trailing arms and parking brake done by Vansteel-a little more than a bolt in -as the top coilover/shock mount has to have a reinforcement bracket welded on.
Also- I had to redo the rear brake line-using the Wilwood Calipers as it was too close to the coil for my liking.
And the stock swaybar might have some interference w/ the rear tires- Vansteel sells one that will work.
DSCN0812.jpg~original by Richard Hayes, on Flickr
DSCN3920_zps92fb8c93 by Richard Hayes, on Flickr
DSCN4080 by Richard Hayes, on Flickr
P1010601.jpg~original by Richard Hayes, on Flickr
DSCN4451 by Richard Hayes, on Flickr
Old Jul 8, 2015 | 11:43 PM
Charliebates
Looks real good. You'll have many here drooling with envy
To Coil overs
