when this part breaks it sounds like???
Old Aug 9, 2002 | 10:34 AM
ykp53's Avatar
ykp53
Default when this part breaks it sounds like???
two days ago my car started boging down when i stoped and had it in drive, i opened the hood and noticed as it bogged down i could hear a clank come from the front of the engine. ( the fan area ) it is not on a regular bassis either, sometimes it makes the noise for two or three second some times only once. i know it's not the alternator, because i already changed it out today and it still does it. so my question is what does a water pump sound like when it is going out? or does a power sterring pump make any noise when it is going out? ( even if the wheels are straight).
[Modified by ykp53, 12:33 PM 8/9/2002]
Old Aug 9, 2002 | 12:47 PM
JIM's Avatar
JIM
Default Re: when this part breaks it sounds like??? (ykp53)
When any part or component fails it sounds like this CHA CHING $$$$$
Old Aug 9, 2002 | 04:23 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: when this part breaks it sounds like??? (JIM)
:lol: :lol: Yep, thats what I hear.
Old Aug 9, 2002 | 04:26 PM
VetteRN's Avatar
VetteRN
for sure! :lol:
Old Aug 9, 2002 | 09:07 PM
73454's Avatar
73454
:D $$$$ :D
If you can move the fans prop shaft on the water pump in/out or side to side it's shot. I would also look at the harmonic balancer to make certain that nothing is behind it or if there is any ring separation going on.
Good Luck
To when this part breaks it sounds like???
