Strange L-48 stumbling
Old Feb 20, 2015 | 01:04 AM
Strokemyaxe's Avatar
Strokemyaxe
Default Strange L-48 stumbling
Hello all!
I have a strange issue. And I can't seem to find anyone else that has had the same issue. Two separate rpm specific issues.
First, From a dead stop wot it climbs steady till hitting 2300 rpms then struggles dramatically to pull to reach 2500 rpms. Acceleration drops significantly here.
Second... Moving on through the rpm range at around 2900 it stumbles heavily once then continues to climb up the rpms.
The power band is so spotty feeling throughout the rpm range.
Any ideas? Motor and trans where rebuilt right before it was out up 15 years ago. Likely has less than 5k miles in em.
Any ideas where or how to start trouble shooting components?
Thanks!
Old Feb 20, 2015 | 07:01 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
When was the last tune up? Fouled/old plugs and/or bad wires can raise some hell but are not so noticeable at low RPM's.
Old Feb 20, 2015 | 09:12 AM
74modified's Avatar
74modified
Of course, I would check the ignition and tuning, but you could have exhaust restriction from converter or pipe/mufflers. There is also fuel restriction from plugged filter/s or tank sock, or pressure/volume from fuel pump. My first check would be replacing the fuel filter and a tuneup.
Old Feb 20, 2015 | 09:51 AM
Strokemyaxe
Thanks for the replies. New plugs went in a few months back. The wires seem to be in tip top. I can't imagine exhaust restriction causing that exact rpm stumble but then again, I have headers and new mufflers that will be going on in a few weeks anyhow, so we will see.
Since the issue is so precise and consistent, I'm thinking the distributor is the culprit. But that thing looks like it's brand new on the inside. Definitely not the original build.
Old Feb 20, 2015 | 01:59 PM
Jud Chapin's Avatar
Jud Chapin
I would test the plug wires as you can't go by looks.
Old Feb 20, 2015 | 02:17 PM
Strokemyaxe
I will get right on that then. Question. Would faulty plug wires cause such a specific stumble at those RPM points? This happens like clockwork.
Old Feb 20, 2015 | 03:08 PM
Jud Chapin's Avatar
Jud Chapin
The miss is there at lower RPM's with bad plugs or wires, you just don't feel it as much. Ask me how I know. Bottom line on this problem is that you have to keep eliminating possibilities until you find the cause. (Do the easiest things first.) At this point, you don't know whether it's gas on electrical in nature. Also keep in mind that no one on this forum or anywhere else knows the answer w/o doing actual troubleshooting on the car.
BTW, don't forget the cap, rotor and filters including the one in the carb. I would also check fuel pressure. Check it at idle and then by reving the engine to verify both readings are within spec. And how old is the gas?
Good luck. Stay with and you'll find the answer.
Old Feb 20, 2015 | 03:37 PM
74modified's Avatar
74modified
He is correct, no one knows without doing the work. On thing, if it is electrical, it is more likely to act up sitting still in neutral, or all the time. Fuel is more likely with a load - driving. But nothing is exact using words on the internet.
Old Jun 14, 2026 | 01:53 AM
RustyDuster's Avatar
RustyDuster
I have the same car, 88 with L98 and 161k (maybe replaced engine). Either way, it will chirp the tires with the accelerator just halfway down. I don't want to push her any harder than that, heck she's almost 40.
To Strange L-48 stumbling
