1979 heater core replace
Old Aug 9, 2002 | 01:31 PM
ronkellogg's Avatar
ronkellogg
Default 1979 heater core replace
Help! hOW DO I REPLACE THE HEATER CORE IN A 1979 WITH AIR? I HAVE STARTED TAKING THE BOX OUT FROM INSIDE THE CAR BUT SOMETHING SEEMS TO BE HOLDING THE LOWER RIGHT SIDE. IS THERE A BOLT THAT I HAVE TO REMOVE FROM OUTSIDE? I DID HAVE TO REMOVE A NUT FROM UNDER THE HOOD ON THE TOP LEFT.
Old Aug 9, 2002 | 03:36 PM
Marc01's Avatar
Marc01
St. Jude Contributor
Default Re: 1979 heater core replace (ronkellogg)
I did this about a month ago on my '78. I ran into the same exact problem. However, I don't know that I can give a solid answer because I just kept uncrewing anything near that area.
First, I assume you've unhooked the heater hoses and removed the clamps? Number one thing to get caught.
Second, there were some really obscure bolts hiding out underneath the evaporator housing. You can get to them from under the car and they go through the evap housing and into the firewall.
Again, not sure which one was actually holding anything on, but once I did all of that, it slipped right out (after angling it different ways)
Old Aug 9, 2002 | 04:57 PM
drspeedy's Avatar
drspeedy
There's a great resource (complete with images) for changing out your heater core on the Corvettefaq.com page:
http://www.corvettefaq.com/misc.asp
The page for the '79 is sans AC, but there's a '70 with AC showing how to take it out through the interior.
When you say right, do you mean lower driver side or passenger side? The core has to come loose on the passenger side first.
You'll have to take out all the nuts from the heater distributor studs, but I can't remember- I'd have to go look to see how many there are on the engine side.
-doc
[Modified by drspeedy, 4:38 PM 8/9/2002]
Old Aug 9, 2002 | 06:14 PM
Paul L's Avatar
Paul L
Default Re: 1979 heater core replace (drspeedy)
That is my series of pics for a non-A/C 1979. But with A/C the core will NOT come out the firewall. Just a tip!
Old Aug 9, 2002 | 06:22 PM
drspeedy's Avatar
drspeedy
Default Re: 1979 heater core replace (paul79)
Cool! Great set of pics. Hope you don't mind me linking to it...
Old Aug 9, 2002 | 06:27 PM
Paul L's Avatar
Paul L
You will find a series of the pics here. My descriptive album was lost when Photopoint went bankrupt. I still have the original pics on my hard drive but not as an album.
http://forums.corvetteforum.com/zerothread?id=272011
Old Aug 10, 2002 | 05:04 PM
ronkellogg's Avatar
ronkellogg
thanks for the help. Because the hoses for the heater core with air come from underneath the car I just had to raise the box while pulling it out. I just hope it goes back together.
To 1979 heater core replace
