Gen light question
Old Feb 22, 2015 | 01:38 PM
danh77's Avatar
danh77
Default Gen light question
This is on my 77. So changed out my leaking heater core and now putting everything else back and here's what has been changed new h/ll switch, new low fuel module. Now when I start the car the volt gauge doesn't move but if I turn on the h/l the volt gauge goes up to where it always used to and then if I turn the lights back off the gen light comes on. I removed the fuel light module(there wasn't one there before the core change) but nothing changed still getting the same issue. Everything worked fine to begin with so I assume it's something dumb that I've done, any ideas? Also are there any symptoms associated with a bad circuit board?
Old Feb 22, 2015 | 01:47 PM
cagotzmann's Avatar
cagotzmann
Does your alternator light come on before you start the car ?
Did you need to remove the center cluster guage panel. If you did then the connector on the back of the cluster has a poor / broken connector for the alternator warning light. If this is the case you also will not be getting a proper output from the alternator to charge your battery.
Old Feb 22, 2015 | 01:53 PM
danh77's Avatar
danh77
Gen light doesn't come on before starting car. Center cluster was out as I had the whole dash out for various repairs while doing the core. I will go back out in a bit and unplug the cluster and see if anything changes
To Gen light question
