Adj low pressure switch
Old Aug 9, 2002 | 07:24 PM
FeedVaal's Avatar
FeedVaal
Default Adj low pressure switch
When I did the A/C conversion to 134a, I used a later model adj low pressure switch which had completely different threads naturally. I cut threads in a brass fitting to mate it up and then JBwelded the whole thing and thought I was good to go but it apparently leaks enough to drain the system after a month. Did any of you that have done this find an Adj switch that fits up like the old one or alternately just use the old switch with success? :confused:
Old Aug 10, 2002 | 02:31 AM
FeedVaal's Avatar
FeedVaal
Default Re: Adj low pressure switch (FeedVaal)
TTT
