Camshaft discussion
Just curious what yall are running without having vacuum issues.
Trying to figure out if I can get by with a XE274 comp cam without having to use a vacuum canister. Furthermore, trying to figure out if it's worth the increase in duration with a 1500-6000 rpm power band.
Bottom line keep the 268 or bump it up to the 274
http://www.compcams.com/v002/Pages/389/XE274H-10.aspx
Those Xe's have a pretty steep ramp for a flat tappet and are more prone to wiping a lobe.
I just got the cam out last night and it was smaller than I thought it was, which would explain the idle and lack of lope. I believe that the old cam was a 250h or 256h.
The heads are going on next week so I still have the pre-89 vortec heads still on the car. I am taking it to the race/speed shop to have them installed. For the amount of money that I am spending on components I want to make sure everything goes in as it should. Its not that I cant do it I just dont feel like spending money on a stupid error on my behalf. Also, I would sleep easy knowing that someone with over 40 years of mechanic time is putting the parts on.
On the other hand I have really thought about converting to the roller lifters but I dont know if its worth the extra $250 to do so. Hydraulic Flat Tappet cams are not a bad cam from my experience but if I make it past the break in I should be good right!?
Everything should be in and complete in a week or two. However, the owner of the speed show highly recommends that I stick with the XE268 over the XE274. Not sure why that would matter as I have a stall in the car and the vacuum should be sufficient given the comments from others on the forum. It could be that this will be the best match for the heads that he is building.
As the heads get better at flowing air the need for greater duration to get the same level of performance decreases. So it could be the speed shop owner knows how well these heads are going to flow.
Getting past the break-in is the biggest hurdle for flat tappet but you still have the potential to have a wiped lobe down the road.
Part of the problem may be that since OEM's are not making flat tappet engines in massive quantities that the flat tappet cam suffers from lack of quality manufacturing that used to exist when it was used exclusively.
That combined with the XE's design in that it lifts the valve very rapidly with less rotation of the cam put the lobe under greater stress. The difference between the advertised duration and the duration at .050 is 44 on the XE274 and the XE268. If the difference in these two numbers is less than 50 then it is a steep lobe. This makes the flat tappet cam's job a lot harder and imposes pretty high side loads making a wiped lobe more likely.
My roller cam is a 270 advertised duration and a 219@.050. a difference of 51, and this is on a roller cam.
Do some searches on wiped lobes. See what the circumstances surrounding the wiped lobe were and the consequences afterwards.
If you have Vizards book "How to build max-performance Chevy small blocks on a budget" look up the cam overlap section in chapter 7 page 91, and see what he has to say about overlap selection governing cam choice.
Brother your money!!!!
Thats some great information and advice that you have listed up there.
I have done some research on the Comp flat tappets and there have been some issues in the past couple of years. But the majority seem to be satisfied with what the one they have been putting in their cars. But you know how that goes these days.
I am also looking and the Lunati Bootlegger in the Hydraulic Flat Tappet, which is all new this year. They have put a ton of research into this cam so you would assume that it is a good product.
Also good points on the overlap I forgot to touch on that.
66.5* of overlap would make the idle pretty rumpity I would think.
I like the 108 LSA's as well for midrange power. They do present their own challenges at idle though. More overlap and smellier idle exhaust.
I have the original TH350 with the stock gears. The trans will be my next mission after I finish the engine. Anyways I am shooting for 425-450hp that is my optimal goal. I think with all the mods i should be in the ball park. I am also really considering going full roller a lot less headaches if i go that route. I just wont tell the wife. Shhhhhhhh.
