install a 30 PSI oil warning light
Old Aug 10, 2002 | 10:39 AM
Matt Gruber's Avatar
Matt Gruber
Default install a 30 PSI oil warning light
ever wonder if going around a fast corner causes the oil pump to suck in some air?
Do you check the oil pressure gauge every 15 seconds?
i have installed a sender that triggers a red light on top the dash if pressure drops below 30.
i used black construction paper to roll a tube about the size of a cigarette, with a red light inside. the black paper makes it blend in with the dash, and the 3" tube, with the bulb in the back, shields it from sunlight.
a little elmers glue seals the tube and attaches it to the dash.
The light flickers when hot at idle in drive, right at 30.
Now i check the gauge once a month :lol:
got the sender from Jegs $13.99
Old Aug 10, 2002 | 11:59 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: install a 30 PSI oil warning light (Matt Gruber)
Cool tip Matt. Got a part number for the sensor?
Dave
Old Aug 11, 2002 | 12:56 AM
Schmucker's Avatar
Schmucker
Doesn't this defeat the purpose of a guage?
Old Aug 11, 2002 | 08:11 AM
Matt Gruber
Default Re: install a 30 PSI oil warning light (Schmucker)
Dave,
the part # is 105-3242
Schmucker,
the gauge is still there to check anytime you want, the light warns you when you are NOT looking at it.
Old Aug 11, 2002 | 10:34 PM
CDaniel525's Avatar
CDaniel525
very cool Matt.....A lot of guy into serious racing use these, but get them from autometer. ive been thinking about adding once, cause at WOT going down the track, I dont have the time to look at hte gauge, so if something goes wrong, itll blare in my eyes. Looks just like a shift light, but in red.
To install a 30 PSI oil warning light
