intake replacement
Old Mar 6, 2015 | 06:53 PM
caryb78's Avatar
caryb78
Default intake replacement
Need to replace my intake on 78 L-82. Any suggestions on intakes that will give me the hood clearance?
Old Mar 6, 2015 | 08:44 PM
Shark Racer's Avatar
Shark Racer
Why do you "need" to replace it? Is it cracked or otherwise damaged?
What are the specs of the engine you are running?
If the intake is damaged and the engine is designed to run <6000 RPM, I'd go with a Performer 2101 (3701 if EGR is required) or a GM ZZ4 intake (10185063). The ZZ4 will fit a little better, the Performer may make a *hair* more power, not much though. Both will fit under a stock 78 hood.
If the engine is designed to run a bit higher RPM, a Performer RPM is good but you'll need a drop-base air cleaner to fit it. Assuming you're running a Q-Jet, you'll want the 7104 (RPM Q-Jet)
Old Mar 6, 2015 | 09:00 PM
mikem350's Avatar
mikem350
Remember to figure out throttle, trans kickdown, vacuum ports and throttle spring changes.
And as said air cleaner!
Old Mar 7, 2015 | 01:29 AM
waynelap's Avatar
waynelap
I run a Holley Street Dominator and a Summit Racing carb, used the original Q-jet on this intake also. The air filter is a standard Car Quest pt#R87095. I believe there is a thread some where with all the different set ups people are running with no clearance issues.
Old Mar 7, 2015 | 01:36 AM
Robert Thomas's Avatar
Robert Thomas
Army Hoist Operator
I have a used Edelbrock 2101 manifold I'd sell for $65, shipped!
Old Mar 7, 2015 | 02:43 AM
waynelap's Avatar
waynelap
It's too bad I'm up in the great white north I'm looking for one for my 84
Old Mar 7, 2015 | 10:14 AM
caryb78's Avatar
caryb78
Default 78 pace L-82 intake replacement-why
Have been having terrible time chasing gremlins. Turns out manifold is warped. I am having it machined but would like to know options if it doesn't work out. Thanks for the response
Old Mar 7, 2015 | 10:28 AM
caryb78's Avatar
caryb78
Default manifold for sale
Ill buy it if still available
caryandann@aol.com Cary Brown, 603 828 9616 - let me know and we will make arrangements
To intake replacement
