Taurus Electric Fan
Old Mar 11, 2015 | 06:49 PM
76yellow's Avatar
76yellow
Default Taurus Electric Fan
I now have my TPI installed. Now I have to get rid of the fan on the water pump. I put a Ford Taurus fan in my 68 & it fit like it was made for it. The problem is I don't remember what year Taurus it was from. Would anybody know what would fit the best ?
Old Mar 11, 2015 | 08:10 PM
'75's Avatar
'75
I believe 87 to 93 with a 3.8 liter will have a 2 speed fan.
Old Mar 11, 2015 | 09:20 PM
76yellow's Avatar
76yellow
Thanks Much !
Old Mar 11, 2015 | 09:27 PM
7t9l82's Avatar
7t9l82
mark viii had a great fan.
Old Mar 11, 2015 | 09:42 PM
'75's Avatar
'75
If I had it to do again, I would look into that one or the Focus dual fan also.
Old Mar 13, 2015 | 08:53 PM
76yellow's Avatar
76yellow
Thanks Guys...I ordered a Focus duel fan. Now I just have to figure out the best way to control them !
Old Mar 14, 2015 | 12:17 PM
scrappy76's Avatar
scrappy76
I am running the 2 speed Taurus fan. Works great and cools great. I wired mine where the low speed is controlled by a thermostat. and the high speed is on a toggle switch Use relays, do not wire directly.
Old Mar 16, 2015 | 08:23 AM
76yellow's Avatar
76yellow
Thanks for your info !
Old Mar 17, 2015 | 09:15 AM
scrappy76's Avatar
scrappy76
Do some searching. I cannot remember the wiring diagram I used, but make sure if you wire the high speed to be controlled by a toggle switch, that there is a relay that shuts off the low speed.
Old Mar 17, 2015 | 01:45 PM
Amorget's Avatar
Amorget
Why not have the TPI ECM control at least the low speed of the fans?
To Taurus Electric Fan
