Noise barrier
Old Mar 11, 2015 | 07:38 PM
kanvasman's Avatar
kanvasman
Default Noise barrier
OK, anyone have any recent first hand experience, pro or con with these noise barriers, Dynamat, hush mat or Eastwood's ThermoCoustic http://www.eastwood.com/ew-thermocou...parent_id=5078
Not necessarily interested in products from HOME CENTERS and more concerned with noise than heat ( If you read between the lines, that means SIDE PIPES). Thanks for any help.
Old Mar 11, 2015 | 08:24 PM
Ontario73's Avatar
Ontario73
I installed the Dynomat on the floors and firewall area this past spring. Installation was actually pretty easy (has the interior out for carpet and seats) and it seems to have removed most of the road noise. I changed from side pipes to a more factory looking rear exit exhaust previously, but, I do notice the sound seems to have moved to rear and not under the floors as previously.
Old Mar 12, 2015 | 02:04 PM
vetteguy22's Avatar
vetteguy22
I also installed Dynamat and have side pipes. It was a very big difference in sound reduction.
Old Mar 12, 2015 | 04:04 PM
REELAV8R's Avatar
REELAV8R
I used this stuff;
Amazon Amazon
on the floor, front and back, inside the door panels and inside the t-top panels. I also have side pipes with STS baffles. Significant noise reduction when the windows are up vs down.
While you are at it, it pays to install the reflexit insulation for heat reduction as well. I have a black car and still it is as cold as I want it to be with A/C and the insulation. Prior to that it was warmer in the cabin and the A/C needed to be on continously.
Old Mar 12, 2015 | 04:43 PM
FKING1's Avatar
FKING1
Dynamat entire interior of my 70.
Car has a high po 383 and can't really notice much difference in the noise level (Headers & Flowmasters too.)
Heat much less.
Old Mar 12, 2015 | 05:25 PM
kanvasman's Avatar
kanvasman
Thanks to all for the feedback. I think I have my answer. People who take the time to add to a thread like this must like what they are using. Thanks.
Old Jul 31, 2019 | 11:17 PM
JKore13's Avatar
JKore13
DWillys,
Thanks for the great info!
Any photos of your work ?
Interested in doing similar-
Joe
Old Aug 5, 2019 | 06:45 AM
Street Rat's Avatar
Street Rat
Dynamat covered by Dynaliner keeps the heat, vibration, and noise in check
Craig
Whoops just noticed how old this thread is.
To Noise barrier
