#2 Body Mount removal
Old Mar 11, 2015 | 08:41 PM
1986coupe's Avatar
1986coupe
Default #2 Body Mount removal
1976 Stingray. All parts required to raise body have been removed.All body mount bolts are out...except #2. It just keeps spinning. I raised the body as much as possible and it lifted the frame off of the front and rear jack stands.
I have avoided cutting the bolt head off since it still gives me some hope that by turning it that it will eventually come out. I think I have given up on that.
Any recomendations from anyone who has had a similar problem?
Old Mar 11, 2015 | 09:38 PM
KENS80V's Avatar
KENS80V
I just ended up cutting the bolt head off. The nut is held in a cage and at this stage the cage is no longer stopping it from spinning. You basically have no other option at this point.
Old Mar 12, 2015 | 09:40 AM
redcruz1120's Avatar
redcruz1120
St. Jude Donor '09
Agreed!! and the new rubber mounts come with new bolts anyway!
Old Mar 12, 2015 | 09:48 AM
SB64's Avatar
SB64
It's a long shot but if you can get to the cage itself with a channel lock or pliers and squeeze the cage enough to stop the bolt from turning you might get lucky.
r
Old Mar 12, 2015 | 01:04 PM
Aquarian's Avatar
Aquarian
Do the cut...Had to do the same thing on my 75.
Old Mar 13, 2015 | 06:42 PM
1986coupe's Avatar
1986coupe
This was supposed to be a simple change of body mount rubber. I had a feeling something was going to become difficult. It looks like I will have to cut it then put a new #2 mount on the frame.
To #2 Body Mount removal
