No power
Old Mar 12, 2015 | 06:32 AM
calvette 11's Avatar
calvette 11
Default No power
I took my 76 to the muffler shop Monday. It cut when I pulled into the lot. There is no power to the interior or alternator. There is power at the starter .The fuse box is dead. Does any one have a idea as to what has happened
Old Mar 12, 2015 | 06:45 AM
JagNorb's Avatar
JagNorb
Large orange wire connecting battery to fuse box is loose or out. Look for large orange wire coming from battery to fuse box.
Old Mar 12, 2015 | 03:38 PM
dochorsepower's Avatar
dochorsepower
It may sound funny but I've had it happen with a complete battery failure with no warning. One of the cells of the battery just disconnected internally. Quality ain't what it used to be. This just happened last year. Check across the battery terminals.
Old Mar 13, 2015 | 01:26 PM
my 76 ray's Avatar
my 76 ray
It might be the fusible link at the starter.
Old Mar 16, 2015 | 10:41 AM
calvette 11
Default power
I replaced the wire with 30 amp inline fuse, only one wire going into fuse box has power nothing coming out. no power at the ignition switch.
Old Mar 17, 2015 | 06:42 PM
dtianen's Avatar
dtianen
Happen to me once. Car running turned it off to get gas, went to re-start, no power. Turned out to be a compromised grounding cable from the negative battery terminal to the frame.
To No power
