parking brake replacement 68'
Corvette Central Project Split Mod, Part III: Chassis Assembly
Does this answer your question?
Good luck... GUSTO
Good luck... GUSTO
If that is the case we need to address why they no longer do when the "actuating lever" is installed. At this point be sure that there is slack in the parking brake cable where it attaches to the actuating lever or it is disconnected from the lever.
As you can see, the actuating lever has two pieces. The lever, and a cross bar (that fits between the two shoes). The two parts are hinged by a pin and each of the two parts has a "paw" on them that engages the slot in their respective shoe. As the "lever" is pulled forward by the parking brake cable, it pushes the "cross-bar" forward and the cross-bar paw moves the forward shoe outboard. At the same time the paw on the lever is engaged with the rear shoe, and is now pushing that shoe to the rear. The only part of the actuating lever that should be engaging the shoes are the two paws.
If this is the case, there is something wrong with the actuating lever or the slots in your new shoes are not cut deep enough. I would guess that there is an engagement issue and not a problem with the components. Let us know what you discover.
GUSTO
I remember having to "wrestle" with the actuating lever and the shoes for several minutes/got a little frustrated............ before everything popped into place on my '68.
If the actuating lever is engaging the shoes correctly, this action can have only one effect on the shoes, it must move them apart. That is how the parking brake is engaged. If the shoes are not moving as you move the actuating lever, the "paws" can not be engaging the shoes correctly. Any movement of the lever should have a corresponding effect on the shoes moving apart.
Good luck... GUSTO
Good luck... GUSTO
