Help! No spark...
Old Mar 15, 2015 | 02:19 PM
msdeess's Avatar
msdeess
Default Help! No spark...
Had a short in wiring to ignition modulator. Replaced and engine still won't start up (tries, but no spark)?? Hoping I do not have to get into tracing wiring. Any ideas? Thanks! 350 1982 corvette
Old Mar 15, 2015 | 02:32 PM
speedreed8's Avatar
speedreed8
probably ignition control module in the HEI dist. http://www.zip-corvette.com/catalog/...nition-module/
Old Mar 15, 2015 | 02:34 PM
msdeess's Avatar
msdeess
Thanks for the reply. Replaced already. Cap & Rotor too
Old Mar 15, 2015 | 02:49 PM
TimAT's Avatar
TimAT
Disconnect the TACH wire from the distributor. Connect a 12v testlight between the TACH terminal on the distributor and a good ground. Crank the engine. If the testlight blinks when you crank, the pickup coil and module are good. If no blink, then either the module or pickup coil have failed.
Old Mar 15, 2015 | 02:51 PM
msdeess's Avatar
msdeess
Will do. Keep you posted. THANKS! :o)
To Help! No spark...
