Half Shaft angles??
Old Mar 16, 2015 | 09:01 PM
rayy's Avatar
rayy
Default Half Shaft angles??
So like I have stated before this is my first C3 1972 vert. So I am rebuilding the front and rear suspension. The front is a Van Steel coilover setup and the rear is there composite spring with Bilsteen shocks. I am putting 18s on the car and notice that the rear is super high so I order longer bolts but to get the car where it does not look like a four wheel drive it looks as if half shafts are pointed up which I know is not good! I am running a 285 35 18 on the rear but going to a 40 on the aspect ratio still would not help enough. I have seen a lot of C3 run 18s with that tire combo and the ride height looks great. So all of those cars have a terrible angle on there half shafts?? What am I missing? Thought about going to a 275 45 18 but not really wanting to buy new tires. Thanks for any help.
Old Mar 16, 2015 | 09:42 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
If the rear shocks bottom out....will the top of the tires hit against the top of the fender well?
What is the angle of the half-shafts now.....5 degrees/10 degrees/20 degrees/more??????
Old Mar 16, 2015 | 09:50 PM
Locke's Avatar
Locke
Default Half Shaft Angles
The rule of thumb around the racing community was to have them be level as possible at static ride height.
That was with 15" wheels but much taller aspect ratio tires of the time.
Some cars would have the diff crossmember relocated in the frame or the diff mounting point recessed into the crossmember.
The point is that U joints like to run just about level. High angles cause them to move alot which creates heat.
Locke
North Florida Corvette Assn.
Old Mar 16, 2015 | 10:22 PM
rayy's Avatar
rayy
No I don't think it would come close if the shock bottomed out. I don't know the angle but just looking at it with the eye I can see that they are angled up.
Old Mar 16, 2015 | 11:27 PM
my 76 ray's Avatar
my 76 ray
A picture would help a lot.
Old Mar 17, 2015 | 12:41 AM
Bad Bird's Avatar
Bad Bird
Locke
Hey Locke,
Not level at static ride height, but rather around 0.5" higher at the inner (diff. side) than the outer (trailing arm) side. This difference is to ensure that the suspension runs in the most favorable region of the toe steer curve (that is, goes into toe in under bump). When the half shafts are higher at the trailing arm side than the differential side, the suspension goes into toe out under bump - not great!
Old Mar 17, 2015 | 12:46 AM
ddawson's Avatar
ddawson
With 1/2 tank of gas 1/2" difference between the inner and outer like Bad Bird states.
Old Mar 17, 2015 | 09:44 AM
rayy's Avatar
rayy
Hardly any fuel in it right now. I will post some pics later today. I just cant believe that all the lowered C3s I have seen have not had the same problem.
Old Mar 17, 2015 | 09:46 AM
doorgunner's Avatar
doorgunner
Hold on! Let's make sure we are talking about the same thing. (I know what I am picturing....but it may not be what you are seeing)
When you say the half-shafts are angled up.......
do you mean that the end bolted to the differential is higher?
OR......
do you mean that the end that is bolted to the wheel/trailing arm is higher?
Old Mar 17, 2015 | 05:26 PM
rayy's Avatar
rayy
Trailing arm side is higher.
Old Mar 17, 2015 | 06:08 PM
Silvertone's Avatar
Silvertone
Whoa, that's not good. Especially after you fill the tank and get in the diff gets lower. Just curious, a 285/35/18 is about 25.85" diameter tire. How high are your rear wheel openings from the ground right now?
Old Mar 17, 2015 | 08:11 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
No, not good at all. And, not only is adverse toe-steer inherent to the C2/C3 IRS as already mentioned, but the extent to which it occurs increases progressively the further from level the half-shafts travel as a function of the trigonometry in play. This happens in both bump and droop, but is far more important when the rear is more highly loaded in bump. I'd strive to get those inner u-joints ~1/2" above the outers, raising the diff in the chassis if a lower CG is that important to your purposes. While you're at it, I'd suggest checking your front "Z" heights to see if that might also be below the point of diminishing returns up front as well.
TSW
Old Mar 17, 2015 | 08:45 PM
rayy's Avatar
rayy
Default Half shafts
I am 4 deg positive.
Old Mar 17, 2015 | 08:49 PM
rayy's Avatar
rayy
From a good flat sarface to the top ark of the rear wheel well is 26.5.
RBrid's Avatar
RBrid
... I have seen a lot of C3 run 18s with that tire combo and the ride height looks great. So all of those cars have a terrible angle on there half shafts?? What am I missing? ...
Just a thought: A car with old compressed rubber body mounts will sit lower than a car with new mounts.
Do you have new body mounts that make your car sit a bit higher?
Old Mar 17, 2015 | 09:00 PM
rayy's Avatar
rayy
They are about 5 years old.
Old Mar 17, 2015 | 10:27 PM
doorgunner's Avatar
doorgunner
26.5 is a decent heigth. My car with a steel leaf spring was at 29.75" when I bought it....I lowered it to 28.0"....with a full tank and driver it lowers to 27".
Being a rookie, I do not know how a monoleaf affects the body heigth.
To Half Shaft angles??
Old Mar 17, 2015 | 11:12 PM
rayy's Avatar
rayy
Like I said I guess every lowered C3 has a bad angle on the half shafts? I dont think mine is super low.
Old Mar 17, 2015 | 11:39 PM
ddawson's Avatar
ddawson
Yes, more people are worried about stance then performance.
Old Mar 18, 2015 | 02:10 PM
Dodosmike's Avatar
Dodosmike
Has the fiberglass cracked around the #4 mounts?
Its not a weak steel leafspring, so that rules that out
Fiberglass spring to soft?
How long are the spring (end) bolts?
Have a bigger pic? Side view of the car?
dodosmike
