Yellow wire at the starter needed?
Old Mar 20, 2015 | 09:03 AM
Franks73's Avatar
Franks73
Default Yellow wire at the starter needed?
Just double checking. I will be using an MSD 6A box, with an MSD distributor, and coil. I do not use the yellow wire at the starter, correct? Thanks for the help on this forum.
Old Mar 20, 2015 | 09:13 AM
mikem350's Avatar
mikem350
If you mean the wire that connects to the "R" solenoid terminal..its not needed.
Old Mar 23, 2015 | 10:21 AM
Franks73's Avatar
Franks73
Default Starter wire
Thanks, thought so.
To Yellow wire at the starter needed?
