new timing sprocket offset issue
Old Mar 22, 2015 | 03:10 PM
brianPA's Avatar
brianPA
Default new timing sprocket offset issue
Last fall I started a project to replace my heads & cam. At some point it got too cold to work in my unheated garage so I had to quit for the winter. Now that it is getting warm out I am picking up where I left off.
I am installing a new Lunati timing set to replace my original set. When I was installing it I noticed that the sprockets don't line up. The original cam sprocket sticks out about 1/8" from the cam, but the new one is flush. Because of this the cam & crank sprockets are offset by this amount when installed. Do I have the wrong timing set, or is this normal & acceptable?
Here's a picture of the two cam sprockets:
Old Mar 22, 2015 | 03:34 PM
7t9l82's Avatar
7t9l82
its fine, your putting in a much better timing set than that factory garbage.
Old Mar 22, 2015 | 03:45 PM
brianPA's Avatar
brianPA
Thank you!
Old Mar 22, 2015 | 07:28 PM
OMF's Avatar
OMF
You do know you have to replace the lower sprocket as well with that new set.....right.
Not trying to be snippy....just helpful.
Old Mar 22, 2015 | 08:20 PM
mds3013's Avatar
mds3013
I have a Lunati also. No problems. mike...
To new timing sprocket offset issue
