Horrible banging noise in engine
Old Mar 22, 2015 | 05:03 PM
DKDunn04's Avatar
DKDunn04
Default Horrible banging noise in engine
The car has new heads, pushrods, rockers and intake manifold. The engine seems to be running fine, but there is an extremely loud banging noise. Watch the video and you can see. The valve springs that are in these heads are 1.5" single springs. Could the noise be one of the valve springs binding? Thanks for the help.
Old Mar 22, 2015 | 06:35 PM
diehrd's Avatar
diehrd
I would pull the starter check the gear and its release and the flywheel connection.
Old Mar 22, 2015 | 06:44 PM
'75's Avatar
'75
Seems like you have an exhaust valve not opening, then the pressure pops back through the intake. Hard to tell much from the short video.
Old Mar 22, 2015 | 07:22 PM
OMF's Avatar
OMF
I'd pull the valvecovers and have a look at the pushrods. one could be bent or off the rocker.
Old Mar 22, 2015 | 07:26 PM
diehrd's Avatar
diehrd
ARE WE ALL listening to the same clip ........ Engine cranks STARTER drags as it fires up and as it disengages you here a Bang ,, then it bangs again and he shuts her down ..
How on earth is that a valve or push rod ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ?
Old Mar 22, 2015 | 07:32 PM
TimAT's Avatar
TimAT
The duration of the video is too short to really determine what's going on. But whatever it is, it don't sound good. (Sorry for the poor grammar)
Old Mar 22, 2015 | 07:47 PM
DKDunn04's Avatar
DKDunn04
It is 100% not the starter. The clip is short, but it keeps banging after the starter disengages. '75 looks like he's correct. Pulled the valve covers and one of the rockers is so loose it is hanging off the side of the spring. Time to readjust all the rockers. Thanks for all the help, I will post again if that doesn't fix it.
Old Mar 22, 2015 | 08:14 PM
CanadaGrant's Avatar
CanadaGrant
Before you re-adjust the rockers, pull the pushrods and roll them on a sheet or pane of glass to make sure you didn't bend one. Especially the one that is off the rocker....
Old Mar 22, 2015 | 08:18 PM
dmaxx3500's Avatar
dmaxx3500
pull the plugs,take off valve covers,then rotate the eng by hand,does anything hit
Old Mar 23, 2015 | 03:55 PM
DKDunn04's Avatar
DKDunn04
Pulled the plugs, rotated the engine by hand, no weird noises. Then pulled the coil wire and turned the engine with the starter, still no noises. Pulled the rockers and checked the pushrods, and they are all good.
Old Mar 23, 2015 | 04:52 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Good to hear! Did you notice if the individual rocker studs are pulling out of the heads....or do you use the shaft-mounted roller rocker arms?
Old Mar 23, 2015 | 08:58 PM
Indiancreek's Avatar
Indiancreek
Put a timing light on it and see by moving from plug to plug if it happens on a particular cylinder. Sounds metallic and substantial to me. Measure the height of the push rods to see if one seems a little higher than the others. Maybe a lifter not smated to the cam correctly. At this point educated guessing.
Old Mar 25, 2015 | 04:58 PM
panic's Avatar
panic
IMG 1168 - YouTube
I have something nasty like your noise but a bit louder coming from the intake too, check link of my thread above:
https://www.corvetteforum.com/forums...ed-please.html
I've pulled the valve covers and checked pushrods and rocker arm, everything is fine and smooth, valves measures intake and exhaust are exactly what the engine builder recommends...
I'm going to check the distributor if something happened there, if that would be the case the timing curve might have gone nuts...
To Horrible banging noise in engine
