Gear ratios?
Old Aug 11, 2002 | 08:42 PM
satx79vette's Avatar
satx79vette
Default Gear ratios?
My current 3.55 rear end is starting to howl quite a bit and I'm looking to replace it with something that would be more suitable for hiway driving (I'm not real keen on 3500 RPMs @ 70 MPH).
Any suggestions as what to go to in order to lower the RPMs some without sacrificing much performance?
Old Aug 11, 2002 | 09:00 PM
SizzleChest's Avatar
SizzleChest
Default Re: Gear ratios? (satx79vette)
3.08s, you could probably find someone who would be willing to trade straight across. good luck.
Old Aug 11, 2002 | 09:18 PM
ED DINAPOLI's Avatar
ED DINAPOLI
3.36 gives you 3000 rpm at 70mph. Little better.
Ed
Old Aug 12, 2002 | 01:34 AM
The Dude's Avatar
The Dude
Yup, 3.08s.
Assuming a 1:1 final drive ratio (like "D" with a TH350), and tires like 245-60s, you'll be turning over about 3,000 RPM at 80 MPH.
Old Aug 12, 2002 | 06:48 AM
Jvette73's Avatar
Jvette73
Do you have automatic or manual tranny? If auto tranny is ok for you then you could switch to 4spd auto with O/D like a 200R4 or 700R4. Get more tQ from the hole plus reduced highway rpms. Best of both worlds. I have 3.90 gear and a 26" dia tire and I rev only 2250@ 65mph with verter locked in 4th gear. 2300rpm@70mph.
Old Aug 12, 2002 | 08:20 AM
mrvette's Avatar
mrvette
IF your gearset is in fact bad, yeh going to what you want is smart...
BUT no gearset change other than 411 to 308 is going to give you the rpm drop worth the money....like an overdrive with decent ratio...say .70 at minimum...
it's just math...your drop from 355 to 308 is allmost meaningless...400 rpm's...
no notice on fuel, noise....hardly worth the bother....
GENE
Old Aug 12, 2002 | 09:07 AM
Neo Fender's Avatar
Neo Fender
Default Re: Gear ratios? (mrvette)
GENE
Yep. I'd replace the gears with the same ratio and consider getting a TH700.
Old Aug 12, 2002 | 01:29 PM
page62's Avatar
page62
I'm doing the 200-4R swap, right here in San Antonio! Pretty soon you'll be able to take advantage of some experienced mechanics...as soon as they finish mine!
By the way 3500 rpm @ 70 mph sounds high! Mine does 3200 @ 70 with stock 3.55s. What size tires do you have? Your bio photo looks like 225/60-15s -- put some 255/60-15s on there and you'll drop hundred rpm!
[Modified by page62, 11:33 AM 8/12/2002]
Old Aug 12, 2002 | 11:14 PM
satx79vette
Default Re: Gear ratios? (page62)
I'm running 235/60-15s that measure roughly 25 1/4" in diameter (quite a bit of rubber left on them).
Old Aug 12, 2002 | 11:16 PM
satx79vette
Default Re: Gear ratios? (Jvette73)
How much would say I would be looking to do something like you suggest in swapping out the tranny?
Old Aug 13, 2002 | 08:46 AM
Neo Fender's Avatar
Neo Fender
Go here: http://www.bowtieoverdrives.com
Old Aug 13, 2002 | 12:18 PM
page62's Avatar
page62
Default Re: Gear ratios? (Neo Fender)
Yup. Bowtie is where I got mine...
To Gear ratios?
