Gasoline Fumes
Old Mar 24, 2015 | 07:11 PM
76yellow's Avatar
76yellow
Default Gasoline Fumes
So I'm done installing my TPI set-up in my 80 Vette. Computer, stand alone harness, required sensors, in tank fuel pump, cam & lifters, etc. I can crank all day but nothing happens. But that isn't my issue here. When I go into my shop it reeks of GASOLINE ! like I spilled a couple gallons on the floor. I've looked everywhere for leaks. The floor is dry, the intake is dry. Where could the fumes be coming from...Ideas ?
Old Mar 24, 2015 | 08:35 PM
bonesbrakr's Avatar
bonesbrakr
Getting fuel and not getting spark so the injectors fire, load up the cylinders, and that's the smell. At least that's my first guess.
Old Mar 24, 2015 | 08:38 PM
LB66383's Avatar
LB66383
IMHO, call the techline for the manufacturer of the TPI. They should be able to give you some clues on where to look. As far as the no-start, spray some starting fluid into the engine and try to start it. If it fires, it's a fuel issue. If it doesn't, it's a spark problem (no spark or bad timing).
Old Mar 24, 2015 | 08:42 PM
76yellow's Avatar
76yellow
Thanks guys...This gives me a place to start !
To Gasoline Fumes
