battery good, car died
Old Mar 28, 2015 | 09:49 PM
bhk2's Avatar
bhk2
Default battery good, car died
After adjusting the distributor with the engine running, I closed the hood--dropping it from a height of ~12 inches. When the hood snapped shut, the car died. Now, the car will not start, battery is still 12.3V, but the only thing that works is the horn. Everything else is dead.
69 350/350, 4 speed, transistor ignition, non AC.
Initial guesses: something with ignition cylinder, an undisclosed ground lost contact...
Earlier in the day the car had been sputtering at highway speeds--like it needed a new fuel filter, H20 in the gas. The unexplained or weird effect happened twice as the car sputtered: the seat belt light came on, and I pushed the button to turn it off. When the car stumbled again, the seat belt turned on.
Old Mar 28, 2015 | 10:02 PM
Roozstr's Avatar
Roozstr
Possible open circuit horn relay to ignition switch.
Old Mar 28, 2015 | 11:09 PM
bhk2's Avatar
bhk2
Great place to start--there is a CF post on diagnosing the horn relay, I'll try to find that again.
How about the key buzzer as a possible culprit?
Old Mar 29, 2015 | 12:11 AM
bhk2's Avatar
bhk2
Roozstr--Bingo--the connection on the fuse link for the horn relay is it!
Old Mar 29, 2015 | 10:46 AM
Roozstr's Avatar
Roozstr
To battery good, car died
