Advice needed: Carb air cleaner stud stripped
Old Aug 12, 2002 | 10:21 AM
Swamp Thang's Avatar
Swamp Thang
Default Advice needed: Carb air cleaner stud stripped
Here's the problem - the air cleaner stud has stripped most of the threads out of the carb (QJet) so that the stud no longer grips in the carb. Any ideas on how to repair this, other than a new carb body? Thanks.
Old Aug 12, 2002 | 10:24 AM
BB wowbagger's Avatar
BB wowbagger
Default Re: Advice needed: Carb air cleaner stud stripped (Swamp Thang)
Is there enogh material to re thread?Or drill out and helicoil. :cheers: :smash:
Old Aug 12, 2002 | 10:26 AM
John D.'s Avatar
John D.
If you still have some treads left try thread lock and let set.
Or I would try some crazy type glue and let set up good.
You don't need much pressure on hold down nut just snug.
This is what I would try .
Old Aug 12, 2002 | 10:27 AM
Matt Gruber's Avatar
Matt Gruber
i would epoxy it in. like JB Weld
hiyosilver's Avatar
hiyosilver
I guess ol Bubba would use apiece of used chewing gum but asmall amount of JB weld ought tt do the trick . :seeya
Old Aug 12, 2002 | 10:31 AM
71-LS5's Avatar
71-LS5
LocTite makes some thread repair stuff that you mix up and put int the stripped out hole. Then you screw in the bolt or screw to thred it it, unscrew and when set up it is suppposed to be repaired. I haven't tried it but you might check it out. All the normal parts houses have it. Good Luck.
Old Aug 12, 2002 | 10:50 AM
Stewart's74's Avatar
Stewart's74
I've used JB Weld on a bunch of stuff. I'd give it a try.
To Advice needed: Carb air cleaner stud stripped
