Detonation problem
Old Mar 30, 2015 | 03:06 AM
PcolaPaul's Avatar
PcolaPaul
Default Detonation problem
Mild 383 with Accel HEI and an early Q-Jet carb.
With total timing advance around 36 to 38° all in @ 4000 RPMs I have a bad detonation problem at wide open throttle. I have to decrease total advance to around 32° to get rid of it. No detonation but the car runs like an absolute pig at 32° total advance. Part throttle and cruise is not a problem. I am running 93 octane fuel. The engine temp runs between 170 and 180°s
I think the engine is about 10 to 1 compression.
2 valve relief flat top pistons .010 below deck height, 68CC heads and .015 "thin" head gaskets.
I am not crazy about pulling the heads and using thicker gaskets to drop the compression some as a fix. I was thinking about going richer on the secondary side of the carb first, then trying a MSD programmable ignition.
Any suggestions would greatly appreciated!
Old Mar 30, 2015 | 04:46 AM
diehrd's Avatar
diehrd
I would say 38 is to much on a small block .. 32 to 34 should be max and you can bring it all in sooner like 2500 rpm . Try that .
Old Mar 30, 2015 | 05:31 AM
zuendler's Avatar
zuendler
Well, the car runs better with detonation?
36° is always a good value btw. timing usually belongs where engine runs best.
If you have to retard until you can feel a lack of power, then I would say you need better fuel. Maybe you have more compression then you think. The engine shop could have decked more then they should. Just as example.
Old Mar 30, 2015 | 09:48 AM
REELAV8R's Avatar
REELAV8R
Wow! You sure about that? That would be a .025" squish. Sounds dangerously like piston hitting head territory.
Give us some more detail. Head chamber size, aluminum or cast iron, and cam specs. The devil is usually in the details.
Just quick computation on CR, if you're using 65cc heads you would be around 11.1:1 CR. With 76 CC heads you're at 9.87, but your DCR is unknown without the cam specs.
Where does it detonate, what RPM range?
edit: oops I see you gave the CC of the heads LOL. Those heads put you at a 10.76 CR with a 7 cc piston, and a .015 gasket.
Old Mar 31, 2015 | 08:30 AM
PcolaPaul's Avatar
PcolaPaul
It's tight but with Lunati internals and a 6500 red-line I feel safe with clearance issues.
I did make some progress. I fattened up the secondaries and went to a colder spark plug. My total advance is 34° and I have minimal ping. I added more initial timing via the adjustable vacuum advance hooked to manifold vacuum. The engine/cam combo likes a lot of initial timing.
I will keep tinkering and might pull the distributor and work on the centrifugal advance in an old Sun distributor machine.
Performance is better,but not where it should be. Last option is an airport a mile from home that sells 100LL for 4 bucks a gallon. I can add a few gallons each fill up to get the octane where I need it. The car is not a daily driver anyway..
Thanks and feel free to add comments.
Old Mar 31, 2015 | 09:44 AM
REELAV8R's Avatar
REELAV8R
Avgas has high octane but is poor from a performance standpoint. Other options may be retarding the cam or reducing valve lift. Depends on where ping is occurring.
what cam you got?
Iron or aluminum heads?
Piston CC's. I just wagged 7 cc's.
Old Mar 31, 2015 | 11:03 AM
OMF's Avatar
OMF
Make sure your vacuum advance mechanism is functioning as it should. It's could be holding onto some advance (possible binding or sticking) as the vacuum goes away.....just something to look at.
To Detonation problem
