Half Shaft Balance?
Old Mar 30, 2015 | 12:13 PM
brian76's Avatar
brian76
Default Half Shaft Balance?
Put a new suspension in the rear of the '76, but forgot to mark the driveshaft when I pulled it. The car is up on jack stands, and when I ran it in gear it vibrated crazy like at about 2000 rpm. So, if I just rotate the drive shaft 180 degrees it should cure it right? Also, I put new half shafts in-are they balanced as well? Thanx
Old Mar 30, 2015 | 01:04 PM
LB66383's Avatar
LB66383
If you're trying to drive with the rear tires up in the air on jackstands, you're going to get vibration. The suspension is hanging down, and the halfshaft U-joints are turning at severe angles. Get the car back on the ground and take it for a drive to see if there is still a vibration.
Old Mar 30, 2015 | 02:42 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you cannot run a corvette with wheels danging in the air.
Old Mar 30, 2015 | 02:51 PM
Tampa Jerry's Avatar
Tampa Jerry
Default Half shafts
Don't worry about balancing the half shafts. They are good to go unless they are bent. Jerry
To Half Shaft Balance?
