Mini Starter
Old Apr 6, 2015 | 07:47 PM
duescherc's Avatar
duescherc
Default Mini Starter
Have a 72 small block was wondering if anyone has used the jegs or summit brand mini starters on the C3. I am having heat soak problems and am wondering the type of mini starters that are working for others.
Old Apr 6, 2015 | 08:03 PM
gdh's Avatar
gdh
I needed a new starter after swapping in a ZZ383 last summer, went with an MSD mini.
Old Apr 6, 2015 | 08:16 PM
jimvette999's Avatar
jimvette999
Mini starter is definitely the way to go. I don't know anything about the brands you mentioned, I don't like anything MSD produces personally. If it were me, I'd use an Advance Auto promo/coupon code and order it online, pickup in store. Just order a remanufactured starter for a 5.7L 94 Chev pickup or a hundred other models. Probably save you $50 or more over other options. You're going to need starter bolts, go to GM dealership parts counter and get them there. The ones that come with some starters are junk. Make sure to get the ones that are knurled on the shoulders. Part number 12338064. Description Bolt/SCRE 2.042 $2.78 each, get 2.
Jim
Old Apr 6, 2015 | 08:29 PM
ddawson's Avatar
ddawson
The shop I use said only get an Hitachi starter so I picked up a Powermaster PowerMAX Plus. He said the other styles can create fitment issues.
Old Apr 6, 2015 | 08:37 PM
gearbreaker's Avatar
gearbreaker
I have a 72 350 with a/c and was having hot starting problems also. I was looking into a mini starter then my starter decided to stop altogether. I put a regular duramax starter (not a mini) from autozone and it starts great now, no matter what I throw at it.
your starter may just be tired also. I know mini starters have a few benefits over standard starters but the cost of my standard made me happy.
Old Apr 6, 2015 | 10:01 PM
Jeff_Keryk's Avatar
Jeff_Keryk
My 68 L36 used to eat reman starters every year. When the Summit mini starter came out, I bit. I reclocked it and it easily fit the 427 with headers. Just installing them is a joke compared to the heavy original starter. Nothin too it.
Probably the best upgrade I ever made.
Old Apr 7, 2015 | 12:22 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I've been using the basic Summit starter for many years on my 540/555. It's a Nippondenso design which is very good and can be clocked to clear just about anything as far as oil pans an headers. It always starts.
JIM
Old Apr 7, 2015 | 08:13 AM
augiedoggy's Avatar
augiedoggy
I had no luck with two of the red ebay hitachi clone mini starters... they cheawed up my flywheel and the teeth on one starter was damaged after a handful of starts...I tried all sorts of shims and watched many videos on how they need to be spaced... Its possible I did something wrong although I managed to build the rest of the engine with the same type of videos and forum support with no issues.
Ended up putting the factory starter back in and so far no issues with my sidepipes... I did pick up the GM style mini stater which is bigger that the hitachi but much smaller/lighter than the stock.. as well as the insulation wrap. Just havent gotten around to replacing it yet.
Old Apr 7, 2015 | 08:48 AM
Scottd's Avatar
Scottd
Jim
THIS IS the way to go. As for the bolts....they arent just junk, they are metric. You will need the bolts listed above. Your going to have to go in with that info ( 94 Chevy 5.7 L engine) as the parts counter guys may tell you 'no such part exists that will fit a Corvette'. (Trust me, I almost strangled the Napa guy over it)
Old Apr 7, 2015 | 08:57 AM
augiedoggy's Avatar
augiedoggy
Thats what Believe I bought to try after I couldnt get the hitachi style to work... The 94 chevy starter which engages the flyweel like the oem starter.
I havent tried it yet but see no reason it wont be a good upgrade to fight off heatsoak from my sidepipes which I'm sure will cause failure on my stock starter soon.
Old Apr 7, 2015 | 09:14 AM
duescherc's Avatar
duescherc
I have heard others mention using a starter from early 90's chevy truck. What makes this a better starter to use.
Old Apr 7, 2015 | 10:37 AM
DaveL82's Avatar
DaveL82
I used a gear reduction starter from a late 80s/early 90s vette when I did my ZZ4 swap. available everywhere and it works great.
Old Apr 7, 2015 | 12:23 PM
BKbroiler's Avatar
BKbroiler
I've been using a Jegs mini starter on mine for years. Works great.
Old Apr 7, 2015 | 12:57 PM
augiedoggy's Avatar
augiedoggy
the idea is the gear reduction starters are stronger and better for higher compression engines (plus they are lighter) and also less likely to burn up from the heat of headers /sidepipe setups... I have almost 10:1 compression and my stock starter has no problems turning over the engine.
To Mini Starter
