Yup, mine is '69 Cortez Silver, same color as your '70. The color really changes given different lighting. These were taken near twilight in the fall, it gave the paint a slightly blue hue. Here are some pics, not the greatest though.....
Let me know if you need the color formula I used for Base/Clear. All the feedback I've gotten on the color is that it's a very good match for the original lacquer.
Thanks 1970Stingray and sb69coupe. I visited both of your sites to get a better look at the color. It's pretty much what I imagined. Your cars look great. I can hardly wait to get ours done.
Would you have the paint mix codes for the cortez silver. I am also interested in restoring car to the original color. I have the bright blue interior/cortez silver combination with a big block. Since this combination seems kind of rare, I'd like to paint it back to the silver.
Problem is, no current base/clear urethanes are mixed to these codes. I had Sherwin Williams do a cross-reference for me, and the match they came up with was for 1998 Nissan code KR4 Sierra Silver Metallic. As I mentioned, I've had an NCRS judge look at the paint and he said it's very close in color and metallic content compared to the original lacquer.
No Problem! That's one of the advantages of having a home office just above the garage. Now if I could keep my 2 year old out of here so I can get some work done :crazy:
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Re: Cortez silver ??? (sb69coupe)
Shannon is correct about the color changing with varying light. When the sun is out full tilt I find it almost impossible to get a decent shot without a lot of glare. On cloudy days the silver appears almost gray in photos.
Cortez Silver is a metallic paint and certainly glistens in the sun! :yesnod:
