82 crossfire electrical prob
Old Apr 12, 2015 | 10:20 AM
Robert P Brueckmann's Avatar
Robert P Brueckmann
2nd Gear
Default 82 crossfire electrical prob
my question is i have changed everything from fuel pump to distributor and car still wont start. pulled car out of garage to try to find why car battery kept going dead jumped battery tested all fuses and realized fuel pump wasnt working Started there , changed fuel pump , ecu, prom ,oil pump pressure sensor. there is power up to injectors .Checked with droid. Found distributor was toast changed that , car still wont start, any thoughts thanks BOB
Old Apr 12, 2015 | 11:20 AM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
Bob, check out our Tech thread for 82's (the "sticky") in the above section. Hopefully this will also help you out in correcting your problem.
https://www.corvetteforum.com/forums...solutions.html
Especially the "NO START CONDITION(S)" section.
Also when you replaced the distributor, did it come with a new ignition module, or did you use your old one? And whether you used either or, did you apply some thermal compound to the bottom of the module to prevent it from getting fired?
you say that you have power to the injectors, so I am assuming that you also have power to the spark plugs? How much fuel is in your tank, if it is under 7 gallons, the pumps may have a difficult time supplying the correct amount of fuel to start. Ask me how I know, at least with mine, I never let it do below that amount, as it will stumble and seem to starve for fuel in stop & go driving.
Again, check out the "sticky".....good luck.....Tom
