Rear leaf spring - different widths or different differential covers?
Old Aug 13, 2002 | 05:14 AM
V8yunkie's Avatar
V8yunkie
Default Rear leaf spring - different widths or different differential covers?
Yesterday the rear axle leaf spring of my baby distorted that way, that only the bottom leaf is connected to the trailing arms but the other leafs have turned sideways thus no more supporting the bottom leaf - so she went down on here rubber stops.
It seems like the leaf spring attachment of the differential cover (I have swapped differentials with a friend from his 79 in order to get 3,55 instead 3,08 ratio) of my "new" differential is wider (i.e. the distance between the 4 bolts holding the spring to the cover) or my spring is not wide enough.
Does anybody know about these differences? Are there two different leaf-spring widths? Or is it the cover that varies? Are there any fixes to reduce distance between the bolts (I am thinking about tubes over the bolts to reduce space between them...).
Any help is highly appreciated!
Old Aug 13, 2002 | 06:23 AM
BB wowbagger's Avatar
BB wowbagger
Default Re: Rear leaf spring - different widths or different differential covers? (V8yunkie)
I think theres 2 diffrent widths of the spring,2 1/4 and 2 1/2...Dont know anymore than this,maybe someone else will chime in and be more accurate.. :cheers:
Old Aug 13, 2002 | 07:36 AM
MassVette's Avatar
MassVette
'78 and '79 have the wider spring..........
:yesnod: :chevy :chevy :yesnod:
Old Aug 13, 2002 | 12:12 PM
redvetracr's Avatar
redvetracr
yunkie,
Go back and swap rear covers with your friend as he will have the opposite problem as you. ...redvetracr
Old Aug 13, 2002 | 01:49 PM
NHvette's Avatar
NHvette
Default Re: Rear leaf spring - different widths or different differential covers? (redvetracr)
When I bought my car, it came with some spare parts: diff cover, spring,
bolts, mounting plate, and a few bags of little parts.
OK - I replaced my diff cover (due to cracked cover and broken bolts) and
spring. The new diff cover was of the "heavy duty" type. It also turns
out that it is for the wider spring. The spring I had was the thinner one.
There is a steel spacer that you can get, which slides inbetween the
bolts and the spring. With this simple spacer in place, it is nice and snug.
I'll try and take a peek this evening, and post any measurements that I can take,
and maybe even a decent picture.
[Modified by Daves_rusty_75, 12:59 PM 8/13/2002]
To Rear leaf spring - different widths or different differential covers?
