Front Left Headlights won't turn on
Old Apr 14, 2015 | 08:56 PM
FirebladeDan's Avatar
FirebladeDan
Default Front Left Headlights won't turn on
I don't have vacuum issues wooo! But my front left lights went up the other day and both low beam and high beam turned off. I went ahead and checked them and both bulbs are fine. Without redoing the entire wiring anyone know any obvious places for me to look?/Has this happened to anyone. **It immediately occurred when light finished going up
Old Apr 14, 2015 | 09:11 PM
65GGvert's Avatar
65GGvert
Did the rear left headlights still work? That's me being funny. It only takes two things to light the headlights: 12v and ground. It sounds like you have a loose connection or broken wire that lost connection when the movement of the light ***'y changed the position of the wire. I'd try connecting a ground to the lamp ground, if it still didn't work, I'd try measuring for 12v to a known good ground and move back toward the wiring and connectors till I found where it was lost. You could also wiggle the connectors and wires and ground connection since it seems to be intermittent based on movement.
Old Apr 14, 2015 | 10:21 PM
Peterbuilt's Avatar
Peterbuilt
http://willcoxcorvette.com/popup_image.php?pID=25658
To Front Left Headlights won't turn on
