rear end rebuilt
Old Apr 15, 2015 | 08:07 PM
Bill Jones's Avatar
Bill Jones
Default rear end rebuilt
I have a 1977 corvette that I'm having a total rear end rebuilt. I have a 7 leaf spring and I'm thanking about going to a composite 1 leaf spring. Please give me pro and cons. Thanks
Old Apr 15, 2015 | 10:57 PM
68/70Vette's Avatar
68/70Vette
I like the composite springs. They weigh about 8 pounds and the iron spring they replace is about 41 pounds. Also, the composite springs are so much easier to replace. The iron springs have an extreme bowing when you want to replace them,...the composite springs have only a few inches of bowing. You have to use a floor jack to jack up the springs to mate to the trailing arms......that the composite springs require only a little jacking up to install them makes the whole operation much more comfortable. The large swinging arc to jack up a steel spring means that if they slip off the jack, they will have EXPLOSIVE energy...the lessened
deflection of the composite makes them much safer to replace.
The composite springs have very little (none) internal damping...you will need a shock absorber with more damping than a shock absorber for the steel springs.
Also, if you order composite springs...know that you can have them reduced in length by 1/2" or so if you want to use offset trailing arms. This reduction in length also helps if you want to run non-stock extra wide tires.
Old Apr 19, 2015 | 01:38 PM
doctorgene's Avatar
doctorgene
Excellent description, some of the Mfg. Co's of Composite Springs do Bow out more than others. This tends to make the car sit way high. in my Opinion. But I would never go back to the metal, unless I was broke Gene
To rear end rebuilt
