Headlight Doors:Ghost in the machine
the control valve needs vacuum to tell the relay to suck the lights DOWN, absence of vacuum on the small line will let the relay go to the default position, meaning put the lights UP......for obvious reasons....
so you need a vacuum wiring/routing diagram and go from there, but this maybe enough to get your started....
BTW the center large hose is under full vac from intake manifold....and so changes state in the relay, telling the canisters to life/drop the lights....
most frequent problems are the 'witches hat' seal on the operating canisters, where the output lever goes to the lights, maybe the relay itself......or some dries up hose over some ~35 years or so....
hate it when my hose dries up.....
I'll look into this tonight, appreciate the mental picture of the system up front--I suspect the vacuum lines are the culprit, and/or their connections with operating parts. Will replace the below dash switch when I get it also--seems like that should be working even with the symptoms going on right now but who knows. By the end of this project I'll have replaced every single piece of this car.
http://www.corvette-101.com/vacuum.htm
Double check your check valve. Any vacuum leak or low vacuum will cause the headlights to go up.
If the engine vacuum is too low, they make an electric conversion.
It's a 22660 mile car I've had for 15 years. (72)
I'm rebuilding a 71, green that was painted red. The car is/ was a mess. I spent a lot of time on the systems. It was learn by reading / doing thing. I was a research/design engineer which helped....
I should have done a frame off on the 71 it's that bad. The frame is spotless.. go figure. Everything else was BUBBAED
I helped my friend with his 70, he has a roller cam and nuts-so engine parts. Huge carb... No vacuum. After checking all the lines, switches and valves.. it was apparent the issue was low vacuum. Hooked up a vacuum pump - 1/4 inch hose from my 1980 truck, the system worked fine.
He upgraded to electric, works great. I'm not fond on the look, as I like stock - he loves it
Any year is great, enjoy the car that is what is most important.... make it yours..
Really appreciate this forum--lots of help.
