C3 body mount cushion #4 advice
Old Apr 18, 2015 | 12:17 PM
hicomp's Avatar
hicomp
Default C3 body mount cushion #4 advice
I need some assistance on replacing the drivers side #4 body isolator/mount on my '75. It took the vehicle in for a safety inspection and they flagged it (I need to fix it to pass).
I've searched the forums and it seems to be a PITA. My questions:
1. Do I need to lift the body to replace just the cushion. I searched the forum and read if you cut the mount you can side it out.
2. Should I just cut the bolt or attempt to unscrew the bolt and risk shearing the rivets on the cage nut.
3. Will I need to replace/repair the mount itself (due to damage during removal)?
Any help or suggestions please.
Old Apr 18, 2015 | 01:30 PM
Mooser's Avatar
Mooser
If you cut the back of the mount off slightly you can sneak it into place without lifting the body.
here's how I did mine without lifting and only a medium amount of bubba
https://www.corvetteforum.com/forums...oval-tool.html
I think I also explained how to bubba a 1-1/2 square tube into a tool to help protect the caged nut
M
Old Apr 19, 2015 | 12:13 PM
hicomp's Avatar
hicomp
M
Thanks. When I searched the forums I did see your previous posts. Just wanted some clarification on the body lift.
When you say cut the "back" of the mount, I assume you mean towards the rear of the car?
Also if I break the cage nut rivets, do I have to remove the outer bracket to access the cage nut rivets?
Old Apr 19, 2015 | 12:26 PM
Mooser's Avatar
Mooser
Yes, it's the shorter one that goes up between the mount and the rear of the fender.
I believe the only way to install new cage rivets is from the top. IIRC access from the bottom is pretty limited with the frame there. Seems to me someone said that support was installed prior to the body drop onto the rear floor sections
M
Old Apr 19, 2015 | 03:30 PM
Dirk76's Avatar
Dirk76
Old Apr 20, 2015 | 04:38 PM
crf311's Avatar
crf311
If you are not worried about being original, you can uses a bolt , washer and a lock nut, instead of changing the cage nut.
Old Apr 20, 2015 | 05:06 PM
hicomp's Avatar
hicomp
Thanks, I will probably do that. I am not concerned (in this particular case). And I read other from other posts on this topic that I could use a hardware store bolt instead of ordering a copy from one of the Corvette suppliers. Basically, it sounds like I just need to order the rubber (or poly?) isolator.
Old Apr 20, 2015 | 05:11 PM
hicomp's Avatar
hicomp
Actually that's a big help because now I don't care about the cage nut!
To C3 body mount cushion #4 advice
