I had a friend who is trying to sell these zz4 heads PN 12556463 you can view them here
http://m.summitracing.com/parts/nal-12556463
My question is will there be a good upgrade to the heads that are installed now, currently have 882 heads.
Also if I were to swap them would I have to do anything else? Have aftermarket open air cleaner, dual exhaust, hooker hugger headers, the cam is changed from stock but do not know dimensions came with the car.
Would be interested in these if they would give me some power and all I have to do is take the old ones off and bolt these ones on. Any advice is appreciated thanks in advance!
Pretty much anything is going to be better than the 882 heads as far as head design goes.
Those ZZ4 heads are 58cc so lots more compression. Aluminum so better comp capability.
Angled plugs. Will they clear your exhaust manifolds?
Question is how are the rings on the current engine. Too much compression and you'll be blowing lots of smoke. Stock pistons are pretty junky cast dish pistons for the L-48 engine, if that's what you got. No real quench on those pistons either.
So ideally even if it blew some smoke I could bolt those right on and run for a while with no damage? Planning a crate engine swap in about a year when I get the funds just looking for some power now since I can get them real cheap.
I have not this brand but this style headers.
http://www.speedwaymotors.com/Tight-Fit-Small-Block-Chevy-Block-Hugger-Headers-Black,3816.html?sku=9300101&utm_medium=C SE&utm_source=CSEGoogle&utm_campaign=CSE GOOGLE&catargetid=530009170000094237&cad evice=m&gclid=CP69n_vGg8UCFdgWgQodbBgASQ
What kind of hp gain you think they will produce? Would it even be worth the work replacing thme?
If you had a motor in very good condition to excellent, the 58 CC vortec heads would give you a significant bump in power but with an engine blowing some smoke with <8.5 compression, raising that compression by 1.5 points I think is asking for trouble. As for the cast pistons, well, lots of guys run 400 HP with cast pistons with no problem. I was at my engine builders shop on Saturday and a kid with a stock C4 LT-1 (cast pistons) with a rear turbocharger running 10 lbs of boost on 106,000 mile LT-1 produced 426 RWHP on a MUSTANG dyno, not a dynojet, through multiple runs and the engine sounded great, no smoke, pretty unbelievable.
oh slight confusion, no the motor runs great now no smoke or leaks at all, was only put in 4k miles ago (not numbers matching) right before i purchased the car from an estate auction the guy died. its been a hassle if you search my other threads to see what i have been working with to figure out whats been done.
The engine runs flawlessly right now and thats why when my friend was talking about unloading these heads on my hands I was wondering if just bolting them up would be a good idea. or if i was asking for a lot of problems, the post above was saying smoke was a possibility and i was questioning about that.
Thank for the replies everyone definitely appreciate the help!
30 some odd years ago cast pistons were pretty crappy, 400 h.p with them would have been dicey, mores now.
the bump in compression will give you a noticeable gain in power, do you have any details about your engine?
